Document ID: c05436119
Version: 1
BIOS update for RP5 Retail System Model 5810
Release date : 21-Mar-2017
Last updated : 28-Mar-2017
DETAILS OF CHANGE
BIOS maintenance update – major changes from 2.32 to 2.33:
  • Add NTFS preboot support in the BIOS F10 menu
  • Fixes issue where user could not disable the Serial Port using the BIOSConfigUtility tool
COMPONENT VERSION
Changing from 2.32 to 2.33
REASON FOR CHANGE
IMPACT OF CHANGE
By default the NTFS preboot support will be disable in the BIOS F10 setup
Components affected:
L20 BIOS Family
DATE OF CHANGE
Effective date : 15-May-2017
Hardware platforms affected : HP RP5 Retail System Model 5810
