HP Spectre 15-Bl000 X360 Convertible PC, HP Spectre 12-c000 x2 Detachable PC - UEFI Diagnostics and HPSA Battery Check Tests Show 4 Cells Voltage Instead of 6
The battery check tests in HP Support Assistant (HPSA) and HP PC Hardware Diagnostics UEFI voltage for 3 cells in advanced settings although the computer battery actually has 6 cells.
Figure 1. Battery test shows 3 cells even though the computer actually has 6 cells (3 pairs)
The computer battery does actually have 6 cells but, because the 6 cells are arranged in 3 series connected pairs, the battery check test reports 3 cells (one for each pair).
NOTE: Cell Voltage 4 (Figure 1) shows 0 mV because the computer does not have the 4th cell pair.
