HP USB-C Travel Hub Specifications
Product image
Figure : HP USB-C Travel Hub
HP USB-C Travel Hub
Ports/cables
Specification
Ports
HDMI1
VGA1
(2) USB 2.0
USB-C power in
Cables
40 cm USB-C cable
Supports multi-function USB-C (video, charging, and USB) and USB Type-C Thunderbolt-enabled ports.
1Supports a single display up to 2048 x 1152 @ 60 Hz (single lane, 5.4 Gbps/lane), 2048 x 1152 @ 60 Hz (two lanes, 2.7 Gbps/lane), or 2560 x 1600 @ 60 Hz (two lanes, 5.4 Gbps/lane).
Power
Specification
Power requirements1
Minimum: 5 V (0.5 A)
Maximum: 20 V (2.8 A)
1Compatible with HP Elite x3. Power adapter not included.
Physical specifications
Specification
Dimensions (H x W x D)
111.2 x 44.2 x 17.1 mm (4.38 x 1.74 x 0.67 in)
0.08 kg (0.176 lbs)
Operating systems
Specification
Supported
Windows 10
Windows 10 Mobile
What's in the box?
Specification
Contents
HP USB-C Travel Hub
Documentation
