HP 9.5mm AiO 800 G3 Slim DVD Writer - Specifications
Physical specifications
Specification
Dimensions (W x H X D)
128.02 x 9.4 x 127.0 mm (5.04 x 0.37 x 5.0 in) without bezel
140 g (0.31 lbs)
Height
9.5 mm (0.37 in)
Orientation
Either horizontal or vertical
Compatibility
Specification
Compatibile with
HP EliteOne 800 G3 AIO 23.8-in Non-Touch
HP EliteOne 800 G3 AIO 23.8-in Touch
Availability varies by country/region.
Technical specifications
Specification
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5 GB DL or 4.7 GB standard
Read/Write speed, media
DVD-R DL
Up to 6X
DVD+R
Up to 8X
DVD+RW
Up to 8X
DVD+R DL
Up to 6X
DVD-R
Up to 8X
DVD-RW
Up to 6X
CD-R
Up to 24X
CD-RW
Up to 10X
DVD-RW, DVD+RW
Up to 8X
DVD-R DL, DVD+R DL
Up to 8X
DVD+R, DVD-R
Up to 8X
DVD-ROM DL, DVD-ROM
Up to 8X
CD-ROM, CD-R
Up to 24X
CD-RW
Up to 24X
Other media
M disc–DVD media for storage presentation
Access time (typical reads, including settling)
Random
DVD-ROM: 170 ms (typical)
CD-ROM: 170 ms (typical)
Full stroke
DVD-ROM: 320 ms (typical)
CD-ROM: 320 ms (typical)
Stop time
6 seconds (typical)
Temperature (operating, non-condensing)
5º to 50º C (41º to 122º F)
Relative humidity
10% to 80%
Maximum wet bulb temperature
29º C (84º F)
Power
Specification
Source
Slimline SATA DC power receptacle
DC power requirement
5 VDC +/-5% -100 mV ripple p-p
DC current
5 VDC (< 1000 mA typical, 1600 mA maximum)
What's in the box?
Specification
Package contents
Optical disc drive (ODD) latch
Bezel
Documentation
