HP Spectre 15-bl000 and 15-ch000 x360 Convertible PCs - Video Output Cannot Be Displayed On Two USB-C Ports at the Same Time
There are 2 USB-C Thunderbolt ports available, but only 1 USB-C Thunderbolt port may be used for video output at a time. Using dual-monitor with Thunderbolt 3 docks and DisplayPort adapters only support 1 display when attached to the Thunderbolt port.
Computers:
  • HP Spectre 15-bl000 x360 Convertible PC series
  • HP Spectre 15-ch000 x360 Convertible PC series
Operating System:
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 Home (64-bit)
Resolution:
This function is by design. Only 1 USB-C Thunderbolt port may be used for video output at a time. If dual video output is desired, use the HDMI port instead of the second USB-C Thunderbolt port.
