HP Notebook - 14-am105nt Product Specifications
Y7Z04EA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
  • AMD Radeon™ R5 M430 Graphics (2 GB DDR3 dedicated)
  • Discrete
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
35.6 cm (14") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 VGA; 1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.1; 1 RJ-45
34.54 x 24.15 x 2.39 cm
1.94 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
FreeDOS 2.0
