HP N220b 21.5-inch Monitor - Specifications
Panel
Specification
Type
IPS
54.61 cm (21.5 in) widescreen
Panel active area (W x H)
47.60 x 26.70 cm (18.74 x 10.51 in)
Resolution
1920 x 1080 at 60 Hz
The video card of the connected PC must be capable of supporting 1920 x 1080 at 60 Hz.
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal/178° vertical typical
Brightness
250 cd/m²
Contrast ratio (typical)¹
1000:1 static
5,000,000:1 dynamic (DCR)
Response times (typical)¹
Gray to gray: 5 ms
Pixel pitch
0.248 (H) x 0.248 (V) mm
Pixels per inch (PPI)
102.4 PPI
Default color temperature
6500K
Backlight lamp life (to half brightness)
30,000 hours minimum
Color gamut (typical)¹
72% sRGB
Color support
Displays up to 16.7 million colors
¹Actual performance varies.
User controls
Specification
Buttons or switches
Menu
Minus (–)
Plus (+)
OK
Power
Languages
English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese
On-screen display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information
Signal interface/performance
Specification
Horizontal frequency
30 to 80 kHz
Vertical frequency
50 to 60 Hz
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
Pixel clock
170 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) HDMI (with HDCP)
Video cables included
(1) VGA cable 1.5 m (4.92 ft)
Power
Specification
Power supply
External
Input power
100 - 240 VAC 50/60 Hz
Maximum power
40 W
Typical power
17 W
Sleep power
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
With stand
49.86 x 15.19 x 30.05 cm (19.63 x 5.98 x 11.83 in)
Head only
49.86 x 3.61 x 30.15 cm (19.63 x 1.42 x 11.87 in)
Packaged
57.38 x 12.40 x 40.01 cm (22.59 x 4.88 x 15.75 in)
With stand
3.0 kg (6.61 lbs)
Head only
2.5 kg (5.51 lbs)
Packaged
4.60 kg (10.14 lbs)
Color
White
Tilt range
-5° to 21° vertical
Stand
Detachable
Security lock ready
Yes
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%
Altitude
Operating: 0 to 5,000 m (0 to 16,404.2 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes
Mercury-free display backlighting
Yes
Eco-label certifications & declarations
China Energy Label: Grade 1
US ENERGY STAR 7.0
EPEAT: Silver
What's in the box?
Specification
Monitor and accessories
AC power cord, 1.9 m (6.23 ft)
VGA cable, 1.5 m (4.92 ft)
Documentation
CD (includes user guide, warranty, drivers)
HP Display Assistant
