    Fix HP Printer issue on macOS
Document ID: c05351017
Version: 1
Advisory: HP EliteBook 725 G3 Notebook PC - Smartcard Insertion or Removal Is Not Detected
Release date : 08-Dec-2016
Last updated : 08-Dec-2016
DESCRIPTION
The following smartcard detection issues are occurring:
Inserting the smartcard
The computer does not detect the card and does not prompt the user to enter a PIN. When this happens, the only way to recover is to restart the computer.
This happens intermittently but frequently.
Removing the smartcard
The computer does not detect that the card has been removed and does not lock the desktop as it should. If the user locks the desktop manually after this, then the user will not be able to log back on to the computer. The only way to recover is to restart the computer.
SCOPE
Computers:
Operating Systems:
Microsoft Windows 10 Enterprise (64-bit)
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
Alcor Micro Smart Card Reader Driver
Version: 1.7.45.10
Revision: A
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/drivers.
Hardware platforms affected : HP EliteBook 725 G3 Notebook PC
Support Communication Cross Reference ID : IA05351017
