    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP EliteBook 820 G4 Notebook PC Product Specifications
Product image
Figure : HP EliteBook 820 G4 Notebook PC
Operating systems
Specification
Preinstalled
Windows 10 Pro 64¹
Windows 10 Home 64¹
FreeDOS 2.0
NeoKylin Linux 64
Web supported
Windows 10 Enterprise 64¹
¹Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply, and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation and forward processors or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-7600U¹
2.8 GHz, up to 3.9 GHz with Intel Turbo Boost technology
4 MB cache
2 cores
Intel Core i7-7500U¹ ²
2.7 GHz, up to 3.5 GHz with Intel Turbo Boost technology
4 MB cache
2 cores
Intel Core i5-7300U¹
2.6 GHz, up to 3.5 GHz with Intel Turbo Boost technology
3 MB cache
2 cores
Intel Core i5-7200U¹ ²
2.5 GHz, up to 3.1 GHz with Intel Turbo Boost technology
3 MB cache
2 cores
Intel Core i3-7100U¹ ²
2.4 GHz
3 MB cache
2 cores
Integrated with processor
¹Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode. Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
²Not available with Intel iAMT (Not available with vPro).
Graphics
Specification
Integrated
Intel HD Graphics 620
Specification
Non-Touch
31.75 cm (12.5 in) diagonal HD SVA anti-glare slim LED-backlit non-touch (1366 x 768)
31.75 cm (12.5 in) diagonal HD SVA anti-glare slim LED-backlit non-touch with camera (1366 x 768)
31.75 cm (12.5 in) diagonal FHD UWVA anti-glare ultra-slim LED-backlit non-touch (1920 x 1080)
31.75 cm (12.5 in) diagonal FHD UWVA anti-glare ultra-slim LED-backlit non-touch with camera (1920 x 1080)
Touch
31.75 cm (12.5 in) diagonal FHD UWVA ultra-slim with camera Corning Gorilla Glass 4 LED-backlit touch screen (1920 x 1080)
Resolution
VGA
External resolutions up to 1920 x 1200 at 60 Hz supported
DisplayPort 1.2
Resolutions up to 4096 x 2304 at 60 Hz supported
Displays support
(3) independent displays supported if used with HP UltraSlim Docking Station
Sold separately or as an optional feature.
Supports dual display through the dock
HD content required to view HD images. Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Specification
SATA, 7 mm 6.35 cm (2.5 in) hard drives
500 GB 7200 rpm Hard Drive
500 GB 7200 rpm Self-Encrypting Hard Drive (Opal 2)
500 GB 7200 rpm Self-Encrypting Hard Drive FIPS-140-2
500 GB Hybrid 8 GB cache
1 TB 5400 rpm Hard Drive
M.2 (NGFF) 2280 solid state drives
128 GB SATA-3 Value Solid State Drive
256 GB PCIe Gen 3x4 NVMe TLC Solid State Drive
360 GB PCIe Gen 3x4 NVMe TLC Solid State Drive
512 GB PCIe Gen 3x4 NVMe TLC Solid State Drive
512 GB PCIe Gen 3x4 NVMe MLC Solid State Drive
256 GB SATA-3 TLC Self-Encrypting Solid State Drive (Opal 2)
512 GB PCIe Gen 3x4 NVMe TLC Self-Encrypting Solid State Drive (Opal 2)
512 GB SATA-3 TLC Solid State Drive FIPS-140-2
HP 3D DriveGuard (Windows and hard drives only)
Hard drive mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for system recovery software.
Memory
Specification
Memory
DDR4 – 2400 SDRAM (Transfer rates up to 2133 MT/s)
(2) SODIMM slots supporting dual-channel memory (Both slots are customer accessible/upgradeable)
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Improved system performance when memory is added in pairs (dual channel). Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Configuration
4096 MB total system memory (4096 MB x 1)
8192 MB total system memory (4096 MB x 2)
8192 MB total system memory (8192 MB x 1)
16384 MB total system memory (16384 MB x 1)
16384 MB total system memory (8192 MB x 2)
32768 MB total system memory (16384 MB x 2)
Maximum
Up to 32 GB
Networking/communications
Specification
Broadband Wireless (WWAN) via M.2 minicard¹
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP lt4132 LTE/HSPA+ with 4G Mobile Broadband Module
HP hs3210 WW HSPA+ with GPS Mobile Broadband
WWAN modules must be preconfigured and require Windows operating system. WWAN connection requires wireless data service contract, network support, and is not available in all areas. Contact service provider to determine the coverage area and availability. Connection speeds vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all areas.
Wireless LAN (WLAN) via M.2 minicard²
Intel Dual Band Wireless-AC 8265 802.11 a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 combo (vPro and non-vPro)
Intel Dual Band Wireless-AC 3168 802.11 a/b/g/n/ac (1x1) Wi-Fi and Bluetooth 4.2 combo (non-vPro)
Communications
Near Field Communication (NFC): HP Module with NXP NFC Controller NPC100 I2C NCI
Intel Ethernet Connection I219-V 10/100/1000 Ethernet (With Intel i3-7100U, i5-7200U, and i7-7500U)³
Intel Ethernet Connection I219-LM 10/100/1000 Ethernet (With Intel i5-7300U and i7-7600U)³
¹Sold separately or as an optional feature. Integrated Bluetooth available.
²Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. Integrated Bluetooth available.
³The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Specification
Audio
Audio by Bang & Olufsen
HP Audio Boost
HP Noise Cancellation software
Digital microphones (Dual array)
(2) Premium stereo speakers
720p HD webcam
Sold separately as an optional feature. HD content required to view HD images. Internet access required.
Keyboards/pointing devices/function keys
Specification
Keyboard
HP Premium Keyboard
Spill resistant with drain
All-metal keyboard deck
Backlit (optional)
HP Dura Keys (optional)
Glass touchpad
On/Off button
Taps enabled as default
Gestures enabled by default
2-finger scrolling
2-finger zoom (pinch)
Function keys
Function keys
F1 - Sleep
F2 - Blank
F3 - Backlit keyboard toggle
F4 - Display switching
F5 - Brightness down
F6 - Brightness up
F7 - Audio mute
F8 - Volume down
F9 - Volume up
F10 - Microphone mute
F11 - Wireless
F12 - Number lock
Hidden function keys
Fn+R - Break
Fn+S - Sys Rq
Fn+C - Scroll lock
Power
Specification
Power supply/AC adapters
HP 45 W Smart AC Adapter
HP 45 W 2-prong DC jack AC Adapter
HP 65 W Smart AC Adapter (supports HP Fast Charging)
HP 65 W Smart AC Adapter EM (supports HP Fast Charging)
Power cord: Either 1.0 m (3.28 ft) or 1.8 m (5.9 ft)
Power cord total length (including external AC adapter): Either 2.86 m (9.38 ft) or 3.66 (12.0 ft)
Availability varies by country/region.
Battery
HP Long Life 3-cell, 49 WHr Li-ion polymer (supports HP Fast Charging with 65 W AC Adapter)
Battery Life
Up to 11 hrs 15 mins (hard drive)
Up to 14 hrs 45 mins (solid state drive)
Windows 10/MM14 battery life varies depending on product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Power conservation
Hibernation
Standby
ACPI compliance
Ports/slots
Specification
Ports
(2) USB 3.1 Gen (1 charging)
(1) USB-Type C (Up to 5 Gbps data transfer and 15 W power)
(1) DisplayPort 1.2
(1) VGA
(1) RJ-45 (Ethernet)
(1) Docking connector
(1) Headphone/microphone combo
(1) AC
Cables not included.
Slots
(1) SD Media Card Reader (SD, SDHC, SDXC supported)
Physical specifications
Specification
Starting at 1.26 kg (2.78 lbs) for non-touch
Starting at 1.38 kg (3.04 lbs) for touch
Weight varies by configuration and components.
Dimensions (W x D x H)
31.0 x 21.89 x 1.89 cm (12.2 x 8.62 x 0.74 in), Front
Height varies depending upon where on the notebook the measurement is made.
Software/security
Specification
BIOS
HP BIOSphere
Available only on business PCs with HP BIOS. HP BIOSphere features might vary depending on the PC platform and configuration.
HP Sure Start Gen3
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase
For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
Pre-boot Authentication
Communication/connectivity
HP Mobile Connect Pro (Windows 10 only)
Available on preconfigured devices with WWAN only.
Native Miracast Support
HP LAN-WLAN Protection
HP MAC Address Manager
HP Wireless Wakeup
HP Value Add Software
HP 3D DriveGuard (Windows required)
HP ePrint Driver and JetAdvantage
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds vary.
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant
Microsoft Products
Buy Office
Bing Search
Skype (not available in China)
Manageability
HP Driver Packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Config Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP MIK for Microsoft SCCM (available for download)
HP Image Assistant (available for download)
LANDESK Management (subscription required)
Client security software
Microsoft Defender
HP Client Security
HP Security Manager (including Credential Manager and Password Manager)
HP Drive Lock
HP Fingerprint Sensor
HP Password Manager
Absolute Persistence Module¹
HP Device Access Manager
Security
Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ certified
Convertible to FIPS 140-2 Certified mode
Fingerprint reader (On select models)
¹Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
