HP Z2 Mini G3 Workstation
Specification
Form factor
Mini form factor
The Z2 Mini G3 can either be placed flat on the desktop or mounted behind a display or under a desk.
note: |
Dimensions
58.0 x 216.0 x 216.0 mm (2.28 x 8.5 x 8.5 in)
(Standard desktop orientation)
Minimum Weight
2.04 kg (4.50 lbs)
Maximum Weight
2.11 kg (4.65 lbs)
Maximum supported weight (desktop orientation)
35.0 kg (77.16 lbs)
Specification
Z2 Mini G3 Performance base unit
Intel Xeon processor
E3-1245v5 with Intel HD Graphics
P530¹
4 cores²
Clock
speed: 3.5 GHz
Intel Turbo
Boost
Technology 3.9³
8 MB cache
Memory
speed: 2133 MT/s
Hyper-threading
Intel vPro
technology
TDP: 80 W
E3-1225v5 with Intel HD Graphics
P530¹
4 cores²
Clock
speed: 3.3 GHz
Intel Turbo
Boost
Technology 3.7³
8 MB cache
Memory
speed: 2133 MT/s
Intel vPro
technology
TDP: 80 W
Intel Core i7-6700
processor with Intel HD Graphics
530¹
4 cores²
Clock
speed: 3.4 GHz
Intel Turbo
Boost
technology 4.0³
8 MB cache
Memory
speed: 2133 MT/s
Hyper-threading
Intel vPro
technology
TDP: 65 W
Intel Core i5-6500
530¹
4 cores²
Clock
speed: 3.2 GHz
Intel Turbo
Boost
technology: 3.6³
6 MB cache
Memory
speed: 2133 MT/s
Intel vPro
technology
TDP: 65 W
Intel Core i3-6100
530¹
2 cores²
Clock
speed: 3.7 GHz
3 MB cache
Memory
speed: 2133 MT/s
TDP: 51 W
Z2 Mini G3 Entry base unit
Intel Core i7-6700
530¹
4 cores²
Clock
speed: 3.4 GHz
Intel Turbo
Boost
technology: 4.0³
8 MB cache
Memory
speed: 2133 MT/s
Hyper-threading
Intel vPro
technology
TDP: 65 W
Intel Core i5-6500
530¹
4 cores²
Clock
speed: 3.2 GHz
Intel Turbo
Boost
technology: 3.6³
6 MB cache
Memory
speed: 2133 MT/s
Intel vPro
technology
TDP: 65 W
Intel Core i3-6100
530¹
2 cores²
Clock
speed: 3.7 GHz
3 MB cache
Memory
speed: 2133 MT/s
TDP: 51 W
note:¹Intel Xeon E3, Intel Core i3, and Intel Pentium processors can support either ECC or non-ECC memory; Intel Core i5/i7 processors only support non-ECC memory.
note:²Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
note:³The specifications shown represent the maximum turbo frequency with one core active. Turbo boost stepping occurs in 100 MHz increments.
Specification
Maximum resolution
DisplayPort 1.2
Up to 4096 x 2160 x 30 bpp at 60 Hz
High Bit Rate 2 (HBR2) and Multi-Stream Transport (MST) supported
HDMI 2.0
Dual Link DVI(I)
Up to 2560 x 1600 x 32 bpp at 60 Hz
Single Link-DVI(I)
Up to 1920 x 1200 x 32 bpp at 60 Hz
VGA
2048 × 1536 × 32 bpp at 85 Hz
note: |
Monitors/displays
HP DreamColor Z24x Professional Display
HP DreamColor Z27x Professional Display
HP Z22n Narrow Bezel IPS Display
HP Z23n Narrow Bezel IPS Display
HP Z24n Narrow Bezel IPS Display
HP Z24nf Narrow Bezel IPS Display
HP Z24nq Narrow Bezel IPS Display
HP Z24s IPS UHD 4K Display
HP Z25n Narrow Bezel IPS Display
HP Z27n Narrow Bezel IPS Display
Specification
SATA hard drives
500 GB SATA 7200 rpm 6 Gb/s SFF HDD
1 TB SATA 7200 rpm 6 Gb/s SFF HDD
SATA solid state drives
HP 256 GB SATA 6Gb/s SSD
PCIe SSDs¹
HP Z Turbo Drive G2 256 GB MLC (Z2 Mini)
HP Z Turbo Drive G2 256 GB TLC (Z2 Mini)
HP Z Turbo Drive G2 512 GB MLC (Z2 Mini)
note: |
note:¹PCIe card installed in standard PCIe x4 slot.
note:For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) of system disk is reserved for system recovery software.
Specification
Integrated
Intel HD Graphics P530 (on select processors)
Intel HD Graphics 530
Entry 3D
NVIDIA Quadro M620 2 GB Graphics (Z2 Mini Performance base unit only)
note:Intermixing integrated Intel HD graphics and discrete graphics cards in order to drive more than three displays can be enabled using the Computer (F10) Setup Utility. However, HP recommends using only discrete graphics when four or more displays are to be supported. Six display solution, achieved using a combination of Intel HD graphics and NVIDIA Quadro graphics, is supported on Windows 10 only.
Specification
Memory
(2) SODIMM slots
note: Up to 32 GB ECC/non-ECC supported
DDR4 2133 MT/s
note: |
DDR4-2400 ECC Unbuffered SODIMMs - CTO
HP 8 GB (1x8 GB) DDR4-2400 ECC RAM
HP 16 GB (2x8 GB) DDR4-2400 ECC RAM
HP 32 GB (2x16 GB) DDR4-2400 ECC RAM
DDR4-2400 non-ECC Unbuffered SODIMMs - CTO
HP 4 GB (1x4 GB) DDR4-2400 non-ECC RAM
HP 8 GB (2x4 GB) DDR4-2400 non-ECC RAM
HP 8 GB (1x8 GB) DDR4-2400 non-ECC RAM
HP 16 GB (2x8 GB) DDR4-2400 non-ECC RAM
HP 32 GB (2x16 GB) DDR4-2400 non-ECC RAM
DDR4-2400 ECC Unbuffered DIMMs - AMO
HP 16 GB (1x16 GB) DDR4-2400 ECC RAM
HP 16 GB (1x16 GB) DDR4-2400 non-ECC RAM
note:Only unbuffered DDR4 DIMMs are supported.
Specification
Audio
Integrated Realtek HD ALC221-VB
CTIA headset supported
Specification
Optical drives
HP External Ultra-Slim DVD-RW Drive
note:Actual speeds vary. Does not permit copying of commercially available DVD movies or other copyright protected materials. Double-layer discs can store more data than single layer discs. However, double-layer discs burned with this drive might not be compatible with many existing single-layer DVD drives and players. With Blu-ray, certain disc, digital connection, compatibility and/or performance issues might arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. In order for some Blu-ray titles to play, they might require a DVI or HDMI digital connection and your display might require HDCP support. HD-DVD movies cannot be played on this workstation.
Specification
Networking
Integrated Intel I219LM PCIe GbE Controller (Intel
vPro with Intel AMT 11.0)
note: Intel 8265 Wireless LAN (802.11ac) and Bluetooth 4.2
Module
note:"Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Specification
Input devices
HP USB 1000 dpi Laser Mouse
HP USB Optical Mouse
HP USB CCID SmartCard Keyboard
HP USB Business Slim Keyboard
HP Wireless Business Slim Keyboard
Specification
Ports, side
(2) USB 3.0 data ports (1 charging)
(1) Headset/microphone combo
Ports, rear
Z2 Mini Performance¹
(4) DisplayPort (DP 1.2) outputs from NVIDIA Quadro M620 graphics
(2) USB
3.0
(2) USB 3.1 G1 Type-C
(1) Serial port (optional)
(1) RJ-45 (LoM)
Z2 Mini Entry
(3) DisplayPort (DP 1.2) outputs from Intel HD graphics
(2) USB 3.0
(1) RJ-45 (LoM)
(1) 30 mm (1.18 in) M.2 slot (PCIe Gen3 x1)
note: (1) 80 mm (3.15 in) M.2 slot (PCIe Gen3 x4)
Expansion bays
(1) internal 6.35 cm (2.5 in) bay (for SATA HDDs & SSDs only)
Specification
System board form factor
200 mm x 200 mm (7.87 x 7.87 in)
Processor socket
Single LGA 1151
CPU bus speed
DMI link between CPU & PCH (Performance comparable to PCIe Gen3 x4)
Intel PCH C236
Memory expansion slots
(2) SODIMM DDR4 memory slots
Memory type supported
DDR4, UDIMM (Unbuffered), ECC and non-ECC
Memory modes
Non-interleaved for single channel
Interleaved when both channels are populated
Memory speed supported
2133 MHz DDR4 for Skylake processors; pre-enabled for 2400 MHz DDR4
Maximum memory
32 GB
note: |
Memory Protection
ECC available on data
note: |
Memory configuration
(supported)
4 GB, 8 GB and 16 GB non-ECC/8 GB and 16 GB ECC unbuffered DIMMs supported
ECC and non-ECC memory DIMMs cannot be mixed on the same system.
SATA
Integrated (1) Serial ATA interface (6Gb/s SATA)
Integrated graphics
A region of system memory is reserved and dedicated to the graphics
display.
Microsoft DirectX 12.1, OpenGL 4.4, and OpenCL 2.0 supported on Intel
HD Graphics P530
DP 1.2 graphics ports integrated
Up to 3 simultaneous displays supported across DP outputs
Maximum resolution: 4096 x 2160 at 60 Hz
Network controller
Integrated Ethernet PHY Connection I219LM
Management capabilities:
WOL, PXE 2.1, and AMT 11.0
Serial
(1) rear port (configurable option)
Flash ROM
Yes
CPU fan header
Yes
Additional CPU/GFX Cooler (Z2 Mini Performance only)
Front control
panel/speaker header
Side In/Out
CMOS battery holder -
lithium
Yes
Integrated trusted
platform module
TPM 2.0
Power supply headers
Yes
Single DC-in jack for external power supplies
Power switch, power LED,
and hard drive LED header
Power and failure LED combined in the front power switch
HDD LED and DC-in LED combined within one port on the Rear In/Out. The LED is lit once the
AC power is plugged in. As soon as the system is booted up, the LED functions as a standard HDD
activity LED.
Clear password jumper
Yes
Specification
Power supply
External
200 W
89% efficiency at 230 Vac
Z2 Mini G3 Entry
135 W
88% efficiency at 115 Vac
Operating voltage
range
115-230 VAC
Rated voltage range
100-240 VAC
Rated line frequency
50-60 Hz
Operating line
frequency range
47-63 Hz
Rated input current
Z2 Mini G3 Performance: 2.9 A at 90 Vac
Z2 Mini G3 Entry: 1.9 A at 90 Vac
ENERGY STAR qualified
(configuration
dependent)
Yes
FEMP standby power
compliant
Yes, with Wake-on-LAN disabled: <1 W in S5- Power Off
Surge tolerant full
ranging power supply
(withstands power
surges up to 2000 V)
Yes
Specification
Form factor
Mini form factor
note: |
Dimensions
Minimum Weight
2.04 kg (4.50 lbs)
Maximum Weight
2.11 kg (4.65 lbs)
35.0 kg (77.16 lbs)
Specification
Preinstalled
Windows 10 Pro 64¹
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro 64)¹ ²
Linux ready
Supported
Red Hat Enterprise Linux Workstation
note: Red Hat Enterprise Linux Desktop 6.7, 7.2
SUSE Linux Enterprise Desktop 11 SP4, 12 SP1
HP Performance Advisor
note: HP Remote Graphics Software (RGS) 7.1
HP PC Hardware Diagnostics UEFI (Windows only)
HP Client Security Software
note:HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: -40° to 60° C (-40° to 140° F)
Humidity
Operating: 8% to 85% RH, non-condensing
Non-operating: 8% to 90% RH, non-condensing
Maximum altitude
Operating: 3,000 m (9,842.52 ft)
Storage: 9,100 m (29,855.6 ft)
Dynamic
Shock
Operating: ½-sine: 40 g, 2-3 ms
Non-operating:
½-sine: 160 cm/s, 2-3 ms (~100 g)
square: 422 cm/s, 20 g
Vibration
Operating random: 0.5 g (rms), 5-300 Hz
Non-operating random: 2.0 g (rms), 10-500 Hz
note: |
Cooling
Above 1,524 m (5,000 ft) altitude, maximum operating temperature is derated
by 1° C (1.8° F) per 305 m (1,000.66 ft) elevation increase.
Security
HP keyed cable lock, 10 mm (.39 in)
