Document ID: c05324614
Version: 1
Advisory: HP Chromebook 11 - Touchpad Does Not Work Properly, Excessive Force Required to Activate
Release date : 03-Nov-2016
Last updated : 03-Nov-2016
DESCRIPTION
The touchpad exhibits any of the following behaviors:
  • Excessive pressure or multiple clicks required to activate the touchpad
  • Click works sporadically or does not work at all but tapping works
  • Cannot click and drag
SCOPE
Computers:
  • HP Chromebook 11 G3
  • HP Chromebook 11 G4
  • HP Chromebook 11 G4 EE
Operating Systems:
  • Google Chrome
RESOLUTION
Update the Chrome OS to version 54 or later (as of 28 October 2016 the latest is version 54).
Follow the link below for instructions on upgrading the OS:
Hardware platforms affected : HP Chromebook 11 G3, HP Chromebook 11 G4, HP Chromebook 11 G4 EE
Support Communication Cross Reference ID : IA05324614
