HP LaserJet Enterprise 700 MFP M725 - 13.89 jam error in the stapler/stacker
Use the following procedure to clear paper jams in the stapler/stacker. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.89.31 Jam in stapler
  1. If paper is visible in the stapler/stacker output bin, grasp the leading edge of the paper and slowly pull the paper out of the printer.
    Figure : Remove paper from the stapler/stacker output bin
  2. Open the upper-left door.
    Figure : Open the upper-left door
  3. Press the green tab down to open the bar.
    Figure : Press tab down to open the bar
  4. Grasp both sides of the paper, and slowly pull the paper out of the printer.
    Figure : Carefully remove any jammed paper
  5. Close the upper-left door. Make sure that both sides of the door snap into place.
    Figure : Close the upper-left door
