HP LaserJet Enterprise 700 MFP M725 - 31.13 document feeder paper jam
Use the following procedure to clear jams in the document feeder. When a jam occurs, the control panel might display a message and an animation that assists in clearing the jam.
  • 31.13.XX Jam in document feeder
  1. Lift the latch to release the document-feeder cover.
    Figure : Lift the latch
  2. Open the document-feeder cover.
    Figure : Open the document-feeder cover
  3. Lift the jam-access door, and remove any jammed paper.
    If necessary, rotate the green wheel at the front of the document feeder to remove jammed paper.
    Figure : Remove jammed paper
  4. Close the document-feeder cover.
    Figure : Close the document-feeder cover
