HP LaserJet Enterprise color flow MFP M575c - 13.B2 right door paper jam
Use the following procedure to check for paper in the lower-right door. When a jam occurs, the control panel might display a message and an animation that assists in clearing the jam.
  • 13.B2.XX Jam in <Cover or Door>.
  1. Open the lower right door.
    Figure : Open the jam-access door
  2. If paper is visible, gently pull the jammed paper up or down to remove it.
    Figure : Remove the jammed paper
  3. Close the lower right door.
    Figure : Close the jam-access door
