    Apache Log4j Update
HP Pavilion x360 13-u111ur Product Specifications
Y7Y71EA
Intel® Pentium® N3710 (1.6 GHz, up to 2.56 GHz, 2 MB cache, 4 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
  • Intel® HD Graphics 405
  • Integrated
500 GB 5400 rpm SATA
33.8 cm (13.3") diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1
32.64 x 22.2 x 1.98 cm
1.66 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Lounge; HP 3D DriveGuard
Pre-installed software
CyberLink PowerDirector
1 month trial for new Microsoft® Office 365 customers
