    Apache Log4j Update
HP Notebook - 15-ay103no Product Specifications
Z5D80EA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
12 GB DDR4-2133 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • AMD Radeon™ R7 M440 Graphics (4 GB DDR3 dedicated)
  • Discrete
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.1; 1 RJ-45
38.43 x 25.46 x 2.43 cm
2.04 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP Audio Switch; HP JumpStart; HP Lounge
Pre-installed software
CyberLink PowerDirector; Netflix
1 month trial for new Microsoft® Office 365 customers
