HP Pavilion x360 - 15-bk117cl Product Specifications
X7U09UA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
  • Intel® HD Graphics 620
  • Integrated
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Intel 802.11ac (1x1) and Bluetooth® 4.0 Combo
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1; 1 RJ-45
38.2 x 25 x 2.39 cm
2.3 kg
45 W AC power adapter
3-cell, 48 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; Dual speakers
HP 3D DriveGuard; HP CoolSense; HP ePrint; HP Games by WildTangent; HP Recovery Manager; HP Support Assistant
Pre-installed software
CyberLink Power Media Player; CyberLink PowerDirector; Dropbox; Netflix
