Specification
Type
60.96 cm (24 in) diagonal IPS with LED backlight
Viewable image area
(diagonal)
60.96 cm (24 in) widescreen
Panel active area (W × H)
51.84 x 32.4 cm (20.41 × 12.76 in)
Resolution
1920 x 1200 at 60 Hz
Aspect ratio
16:10
Viewing angle
Up to 178° horizontal/178° vertical typical
Brightness
300 cd/m2
Contrast ratio (typical)
1000:1 static; 5,000,000:1 dynamic (DCR)
Response times*
8 ms typical (G-to-G)
Pixel pitch
0.270 mm
Pixels per inch (PPI)
94.3 dots per inch
Backlight lamp life (to half brightness)
30,000 hours minimum
Color gamut
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
99% sRGB
Default color setting
DICOM
Actual performance might vary.
