HP 340, 346, 348 G4 Notebook PC - Specifications
Operating systems
Specification
Preinstalled, Windows¹ ²
Windows 10 Pro
Preinstalled, other
FreeDOS 1.2
Neokylin Linux 64
¹Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
²This product does not support Windows 8 or Windows 7. In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on this product or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-7500U with Intel HD graphics 620¹
2.7 GHz with Intel Turbo Boost technology
4 MB cache
2 cores
Intel Core i5-7200U with Intel HD graphics 620¹
2.5 GHz (up to 2.8 GHz with Intel Turbo Boost technology)
3 MB cache
2 cores
Intel i3-7100U with Intel HD graphics 620¹
2.4 GHz
3 MB cache
2 cores
Integrated
Intel SoC
¹Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode. Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance. HD content required to view HD images.
Graphics
Specification
Integrated
Intel HD Graphics
Intel HD Graphics 610
Intel HD Graphics 620
Discrete
AMD Radeon R5 M430 (2 GB DDR3 dedicated)
HD Decode, DX12, and HDMI supported
Specification
Internal
35.56 cm (14 in) diagonal HD eDP anti-glare Slim LED-backlit (1366 x 768)
35.56 cm (14 in) diagonal FHD eDP anti-glare Slim LED-backlit (1920 x 1080)
External
Up to 32-bit per pixel color depth
VGA: 1080p external resolution at 60 Hz
HDMI: resolutions up to 1920 x 1200 at 60 Hz (cable sold separately)
Resolutions are dependent upon monitor capability and resolution and color depth settings. HD content required to view HD images.
Storage/drives
Specification
Primary storage bay
All 7 mm/9.5 mm (.28 in/.37 in), SATA 6.35 cm (2.5 in) hard drives supported
Hard drives and solid state drives¹
500 GB (7200 rpm) SATA hard drive
500 GB (5400 rpm) SSHD (8 GB Cache)
1 TB (7200 rpm) SATA hard drive
256G/512G 2280 TLC M.2 SSD (HP 348 G4 Notebook PC only)
Optical drives (optional)
DVD+/-RW SuperMulti DL Drive
Sold separately or as an optional feature. Double-layer discs can store more data than single layer discs. However, double-layer discs burned with this drive might not be compatible with many existing single-layer DVD drives and players. Note that this drive cannot read or write to 2.6 GB single-sided/5.2 GB double-sided version 1.0 media.
¹For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Specification
Standard
Dual channel memory
DDR4 - 2133 (Transfer rates up to 2133 MT/s)
4096 MB (4096 MB x 1)
8192 MB (8192 MB x 1)
16384 MB (8192 x 2)
Memory is not accessible and cannot be upgraded.
Support
Up to 16 GB
Networking/communications
Specification
Wireless¹
802.11b/g/n (1 x 1) and Bluetooth 4.0 combo
Wireless 802.11a/b/g/n (2 x 2) and Bluetooth 4.0 combo
Ethernet
Realtek Ethernet (10/100/1000) NIC (on select models)
¹Sold separately or as an optional feature. Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Audio/multimedia
Specification
Audio
DTS Studio Sound
Dual speakers
Dual digital microphone (webcam configuration)
Single digital microphone (non-webcam configuration)
Webcam¹
HD camera, no tilt (select models)
1280 x 720 by 30 frames per second
¹Internet access required. HD content required to view HD images.
Keyboards/pointing devices
Specification
Keyboard
Full-sized
Spill-resistant
Touchpad
Taps enabled as default
Multi-touch gestures enabled
Default on for 2-finger scroll and pinch
Software/security
Specification
Preinstalled with Windows
Buy Office
Cyberlink Media Suite
Cyberlink Youcam DE
Security
Firmware Trusted Platform Module (TPM)
Lock slot
Power
Specification
Power supply
HP 65 W EM smart AC adapter (China and India only, not available in all areas)
HP 65 W smart adapter
Battery¹
4-cell 40 WHr Li-ion LLB type
6-cell, 47 WHr Li-ion
Power conservation
Hibernation
Standby
ACPI compliance
¹Windows 10/MM14 battery life varies depending on product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Weight/dimensions
Specification
Starting at 2.0 kg (4.4 lbs)
Dimensions (W x D x H)
34.54 x 24.15 x 2.39 cm (13.6 x 9.51 x .09 in)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration.
Ports/slots
Specification
Ports
(4) USB 3.0
(1) VGA
(1) HDMI (cable sold separately)
(1) Headphone/microphone-in combo
(1) AC power
(1) RJ-45 (Ethernet)
Slots
Multimedia reader
SD, SDHC, SDXC supported
Mini versions supported with adapter
