HP PageWide 300, 400, 500 series - Update the printer firmware
Every HP printer is released with a tested version of the programs (called "firmware") that runs the device. Your HP printer is also designed to support a firmware update process. This allows HP to provide enhancements to printers already sold. Firmware updates can add new features to the product, as well as fix known problems with the product. Updating a product’s firmware ensures that it will work as efficiently as possible.
It is recommended that you update the firmware on your printer whenever a new firmware version is available.
HP recommends automatically updating the firmware on your printer by enabling auto update through the printer Embedded Web Server.
Latest firmware version
The latest firmware version available for the PageWide 300, 400, and 500 series devices, as of April 2019, is 1908C.
Use the instructions in this document to update the firmware on your printer.
IMPORTANT: Before updating the firmware, you should first determine the current firmware version on your printer. If the most recent firmware version is already installed on your product, then you do not need to update the firmware.
Determine the current firmware version on your printer
To determine the current firmware version on your printer, print a Printer Status Report. The firmware version is listed on the report.
Find your printer model in the options below and then click it to expand the section and follow the steps provided to print a Printer Status Report.
There are two options (listed below) for updating the printer firmware. Click the option you would like to use and then follow the steps provided.
