HP ProBook 470 G4 Notebook PC - Specifications
Operating systems
Specification
Preinstalled, Windows¹ ²
Windows 10 Pro 64
Windows 10 Pro (National Academic only)
Windows 10 Home 64 (National Academic only)
Preinstalled, other
FreeDOS 2.0
Web only support¹ ²
Windows 10 Pro 64
Windows 10 Enterprise 64
¹Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
²This product does not support Windows 8 or Windows 7. In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on this product or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i3-7100U Intel HD Graphics 620¹
2.4 GHz
3 MB L3 cache
2 cores
Intel Core i5-7200U Intel HD Graphics 620¹
2.5 GHz, up to 3.1 GHz with Intel Turbo Boost technology
3 MB L3 cache
2 cores
Intel Core i7-7500U Intel HD Graphics 620¹
2.7 GHz, up to 3.5 GHz with Intel Turbo Boost technology
4 MB L3 cache
2 cores
Integrated
¹Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode. Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance. HD content required to view HD images.
Graphics
Specification
Type
Discrete
NVIDIA GeForce 930MX (2 GB DDR3 dedicated, switchable)
NVIDIA Optimus technology requires an Intel processor, plus an NVIDIA GeForce discrete graphics configuration and is available on Windows 10 Professional. With NVIDIA Optimus technology, full enablement of all discrete graphics video and display features might not be supported on all systems (e.g. OpenGL applications run on the integrated GPU or the APU).
Displays
Specification
Internal Non-touch
43.9 cm (17.3 in) diagonal HD+ anti-glare LED-backlit (1600 x 900)
43.9 cm (17.3 in) diagonal FHD anti-glare LED-backlit (1920 x 1080)
External
Up to 32-bit per pixel color depth
VGA: resolutions up to 2048 x 1536 external resolution at 60 Hz
HDMI: direct connection to high-definition displays with resolution up to 4096 x 2160 at 24 Hz and 7-channel audio
Resolutions are dependent upon monitor capability and resolution and color depth settings. HD content required to view HD images.
Storage/drives
Specification
Hard drives¹
SATA 7 mm/9.5 mm (.28 in/.37 in), 6.35 cm (2.5 in) hard drives supported
500 GB (5400 rpm) hard drive
500 GB (5400 rpm) SSHD (Hybrid) (8 GB cache)
500 GB (7200 rpm) hard drive
1 TB (5400 rpm) hard drive
2 TB (5400 rpm) hard drive
Mini card solid state drives¹
M.2 (NGFF) 2280 solid state drive
128 GB SATA-3 Value solid state drive
256 GB SATA-3 Value solid state drive
Dual solid state drive¹
256 GB + 256 GB SATA-3 Value solid state drive
HP 3D DriveGuard (Windows only)
Yes
Optical drives (optional)
Fixed
9.0 mm (.35 in) SATA
DVD-ROM
DVD+/-RW SuperMulti DL Drive
For Blu-ray drives, certain disc, digital connection, compatibility and/or performance issues might arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. Some Blu-ray titles might require an HDMI digital connection, and your display might require HDCP support. HD-DVD disks cannot be played on this drive. Note that DVD-RAM cannot read or write to 2.6 GB single sided/5.2 GB double sided version 1.0 media. Actual speeds might vary.
¹For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Specification
Standard
(2) SODIMM slots (customer accessible/upgradeable)
Dual channel memory
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
DDR4 PC4, transfer rates up to 2133 MT/s
4 GB total system memory (4 GB x 1)
8 GB total system memory (4 GB x 2) (dual channel)
8 GB total system memory (8 GB x 1)
12 GB total system memory (8 GB + 4 GB) (dual channel)
16 GB total system memory (8 GB x 2) (dual channel)
Support
Up to 16 GB (8 GB x 2)
Networking/communications
Specification
Wireless LAN (WLAN) (optional)¹
Realtek 802.11b/g/n (1 x 1) and Bluetooth 4.0 combo
Intel dual band Wireless-AC 3168 802.11a/b/g/n/ac (1 x 1) Wi-Fi and Bluetooth 4.0 combo
Intel dual band Wireless-AC 8265 802.11a/b/g/n/ac (2 x 2) Wi-Fi and Bluetooth 4.0 combo (non-vPro)
Intel dual band Wireless-AC 7265 802.11a/b/g/n/ac (2 x 2) Wi-Fi and Bluetooth 4.2 combo (non-vPro)
Ethernet
Realtek RTL8111HSH (10/100/1000)*
*The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
¹Sold separately or as an optional feature. Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Audio/multimedia
Specification
Audio
(2) stereo speakers
Integrated microphone (dual-microphone array when equipped with optional webcam)
Headphone/microphone combo jack
Webcam (optional)¹
HD camera
720p
¹Internet access required. HD content required to view HD images.
Keyboards/pointing devices
Specification
Keyboard
HP Premium keyboard
Spill-resistant
Separate numeric keypad
Backlit (optional)
Clickpad
Gestures support
2-way scroll
Touchpad
Taps enabled as default
Enabled by default Windows 10
2-finger scrolling
2-finger zoom (pinch)
OSD (enable/disable)
3-finger tap = Cortana
3-finger flick = App switch
4-finger tap = Action Center
Disabled by default Win 10
3-finger flick
2-finger rotate
Momentum motion
1-finger vertical scroll
Software/security
Specification
BIOS
HP BIOSphere
Available only on business PCs with HP BIOS. HP BIOSphere features might vary depending on the PC platform and configuration.
HP DriveLock (HP Automatic DriveLock)
HP BIOS Protection
BIOS update via network
Master boot record security
Power on authentication
Pre-boot security
Secure Erase
Hybrid boot
Measure boot
Secure boot
Absolute persistence module (purchased subscription required)
Multimedia
Cyberlink Power Media Player
Only available with optical drive.
Native Miracast support
HP Value Add software
HP 3D DriveGuard
HP ePrint Driver
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract.
HP Hotkey support
HP Recovery Manager
HP Support Assistant
Microsoft products
Buy Office
Bing search
Skype (Not available in China)
Manageability
HP Driver Packs*
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)*
HP BIOS Config Utility (BCU)*
HP Client Catalog*
HP CIK for Microsoft SCCM*
LANDESK Management (subscription required)
*Available on manageability website.
Security
HP Security Manager
Microsoft Defender
Trusted Platform Module (TPM) 2.0 (1.2 optional)
Lock slot
HP Fingerprint Reader
Pre-boot authentication
Power
Specification
Power supply
65 W Smart AC adapter
65 W EM Smart AC adapter (PRC and India only)
Battery¹
HP 3-cell, Long Life 48 WHr Li-ion
Internal (not replaceable)
Battery life
Solid state drive: Up to 12 hrs and 45 mins
Hard disk drive: Up to 11 hrs
¹Windows 10/MM14 battery life varies depending on product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Weight/dimensions
Specification
Starting at 2.63 kg (5.8 lbs)
Dimensions (W x D x H)
41.68 x 28 x 2.58 cm (16.41 x 11.02 x 1.02 in)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
Ports/slots
Specification
Ports¹
(1) USB 3.0
(2) USB 2.0
(1) USB Type-C
(1) HDMI
(1) Headphone/microphone combo
(1) AC power
(1) RJ-45 (Ethernet)
(1) VGA
Slots
Multimedia reader
SD, SDHC, SDXC supported
¹Cables sold separately.
