    Fix HP Printer issue on macOS
HP EliteDesk 705 G3 Business Desktop PC Specifications
Product images
Figure : HP EliteDesk 705 G3 Microtower Business PC
Figure : HP EliteDesk 705 G3 Small Form Factor Business PC
Processors
Specification
AMD PRO A12-9800 with AMD Radeon R7 graphics
65 W
Up to 4.2 GHz max boost frequency (3.8 GHz base frequency)
2 MB L2 Cache, 4 cores, 8 Radeon cores
Discrete-class graphics
DDR4 memory up to 2133 MT/s data rate
AMD DASH 1.1 supported
AMD PRO A10-9700 accelerated processor with AMD Radeon R7 graphics
65 W
Up to 3.8 GHz max boost frequency (3.5 GHz base frequency)
2 MB L2 cache, 4 cores, 6 Radeon cores
AMD PRO A8-9600 accelerated processor with AMD Radeon R7 graphics
65 W
Up to 3.4 GHz max boost frequency (3.1 GHz base frequency)
AMD PRO A6–9500 accelerated processor with AMD Radeon R5 graphics
65 W
1 MB L2 cache, 2 cores, 6 Radeon cores
Multi-core is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of clock speed.
Software/security
Specification
BIOS
HP BIOSphere with Sure Start
Available only on business PCs with HP BIOS.
HP DriveLock
HP BIOS protection
BIOS update via network
Master boot record security
Power on authentication
Pre-boot security
Secure erase
HP Spare Key
Requires initial user setup.
Hybrid boot
Measured boot
Secure boot
Absolute persistence module
Activated when customers activate a purchased subscription.
Preboot authentication
Multimedia
CyberLink Power media player
Native Miracast support
HP value add software
HP ePrint driver
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Recovery Manager
HP Support Assistant
HP JumpStart
Microsoft products
Bing search
Skype for Business certified (Not available in China)
Manageability
HP Driver Packs*
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)*
HP BIOS Config Utility (BCU)*
HP Client Catalog*
HP CIK for Microsoft SCCM*
LANDESK Management**
Discover HP Touchpoint Manager
HP Image Assistant*
*Available for download.
**Subscription required.
Security
HP Security Manager (including Credential Manager and Password Manager)
HP Drive Lock
HP Fingerprint Sensor
HP Password Manager
Microsoft Defender*
*Opt in and internet connection required for updates.
Trusted platform module TPM 2.0 embedded security chip (SLB9670 - Common Criteria EAL4+ certified)
SATA 0, 1 port disablement (via BIOS)
RAID configurations
Serial, USB enable/disable (via BIOS)
Setup password (via BIOS)
Solenoid hood lock/Intrusion sensor
Chassis padlocks and cable lock devices supported
Graphics/audio/multimedia
Specification
System integrated graphics
AMD Radeon HD graphics
Discrete graphics solutions (optional)*
NVIDIA GeForce GT 730 2 GB PCIe x8
NVIDIA Quadro NVS 310 1 GB PCIe x16
NVIDIA Quadro NVS 310 1 GB PCIe x16, 2nd
AMD Radeon R9 350 2 GB PCIe x16**
**Available for HP EliteDesk 705 G3 Microtower Business PC only.
Audio
DTS Studio Sound with Realtek codec ALC221
Microphone and headphone front ports (3.5 mm (.14 in))
Line-out and line-in rear ports (3.5 mm (.14 in))
Internal mono speaker (standard)
The front microphone port is re-taskable as a line-in, microphone-in or headphone-out port. Rear audio input ports are re-taskable as a line-in or microphone-in port. External speakers must be powered externally. Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks. This allows for different audio applications to use separate audio ports on the system. For example, the front jacks could be used with a headset for a communications application while the rear jacks are being used with external speakers and a multimedia application.
Must be configured at purchase.
Memory/storage
Specification
Memory
DDR4-2133 (Transfer rates up to 2133 MT/s)
Memory modules support data transfer rates up to 2133 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
64 GB
Full availability of 4 GB or more of memory requires a 64-bit operating system.
(4) DIMM slots
8.89 cm (3.5 in) SATA 7.2k rpm hard disk drives*
500 GB 7200 rpm 8.89 cm (3.5 in)
500 GB 7200 rpm 8.89 cm (3.5 in), 2nd
1 TB 7200 rpm 8.89 cm (3.5 in)
1 TB 7200 rpm 8.89 cm (3.5 in), 2nd
2 TB 7200 rpm 8.89 cm (3.5 in)
2 TB 7200 rpm 8.89 cm (3.5 in), 2nd
6.35 cm (2.5 in) solid state hybrid drives (SSHD)*
1 TB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid
500 GB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid
500 GB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid, 2nd
8.89 cm (3.5 in) solid state hybrid drives (SSHD)*
1 TB 7200 rpm 8.89 cm (3.5 in) SSHD (SSHD)
1 TB 7200 rpm 8.89 cm (3.5 in), 2nd, SSHD (SSHD)
6.35 cm (2.5 in) self-encrypting drives (SED)*
500 GB 5400 rpm 6.35 cm (2.5 in) federal information processing standard (FIPS) SED
500 GB 5400 rpm 6.35 cm (2.5 in) federal information processing standard (FIPS) SED, 2nd
500 GB 7200 rpm 6.35 cm (2.5 in) SED OPAL2
500 GB 7200 rpm 6.35 cm (2.5 in) SED OPAL2, 2nd
256 GB SED SSD Opal 2 Drive
256 GB SED SSD Opal 2 Drive, 2nd
512 GB SED SSD Opal 2 Drive
512 GB SED SSD Opal 2 Drive, 2nd
Intel Pro 5400s 240 GB SED Opal 2 SSD drive
Intel Pro 5400s 240 GB SED Opal 2 SSD drive, 2nd
HP Turbo Drive G2 solid state drives*
HP 128 GB Turbo Drive G2 PCIe SSD
HP 256 GB Turbo Drive G2 PCIe SSD
HP 512 GB Turbo Drive G2 PCIe SSD
HP 256 GB Turbo Drive G2 TLC SSD-PCIe
HP 512 GB Turbo Drive G2 TLC SSD PCIe
6.35 cm (2.5 in) SATA solid state drives*
HP Value 128 GB SSD Drive
HP Value 128 GB SSD Drive, 2nd
HP Value 256 GB SSD Drive
HP Value 256 GB SSD Drive, 2nd
Intel Pro 5400s 240 GB SSD Drive
Intel Pro 5400s 240 GB SSD Drive, 2nd
HP 256 GB TLC SSD Drive
HP 256 GB TLC SSD Drive, 2nd
HP 512 GB TLC SSD Drive
HP 512 GB TLC SSD Drive, 2nd
Optical disc drives
HP 9.5 mm (.37 in) Slim DVD-ROM drive
HP 9.5 mm (.37 in) Slim SuperMulti DVD Writer drive
Removable
HP 9.5 mm (.37 in) Slim Removable SATA 500 GB
Media Card Reader (optional)**
SD4 with 5-in-1 interface from SD option to PCA, USB
SD, SDXC, SDHC, UHS-I, UHS-II supported
*For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) of system disk is reserved for the system recovery software.
**Card sold separately.
Networking/communications
Specification
Ethernet (RJ-45)
Integrated
Broadcom NetXtreme Gigabit Ethernet LOM BCM5762 - DASH compliant NIC
Optional
Intel Ethernet I210-T1 PCIe x1 Gb network interface card
Wireless LAN (optional)*
Intel 8260 802.11AC 2 x 2 DualBand PCIe x1 combo card
Intel 7265 802.11AC 2 x 2 DualBand PCIe x1 combo card
*Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Ports/bays/slots
Specification
Ports
(4) USB 2.0: (2) front, (2) rear
(1) front port is fast charging
(4) USB 3.1 Gen 1: (2) front, (2) rear
(2) USB 3.1 Gen 2: rear
(1) Serial (RS-232) connector
(2) PS/2: (1) keyboard with Wake from S4/S5, (1) mouse
(1) VGA
(2) DisplayPort
(1) Headphone/microphone, front
(1) Headphone connector, front
(1) Line in (3.5 mm (.14 in)), rear
(1) Line out (3.5 mm (.14 in)), rear
(1) RJ-45 connector
(1) 2nd Serial (RS-232) port adapter (optional)
(1) HP Parallel Port PCIe x1 card (optional)
(1) USB-Type C, HP SuperSpeed USB 3.1 Gen 2 PCIe x1 card (optional)
(3) Internal SATA storage connectors
Bays
(1) Slim optical disk drive bay
(1) Secure digital (SD) 4 reader
(1) 6.35 cm (2.5 in) internal storage drive bay*
*Available on HP EliteDesk 705 G3 Small Form Factor Business PC only.
(2) 8.89 cm (3.5 in) internal storage drive bays
Slots
(2) PCI Express x1 (v2.0): 11.13 cm (4.38 in) full height, 16.76 cm (6.6 in) length, 10 W maximum power
(1) PCI Express x16 (v2.0) (wired as a x4): 11.13 cm (4.38 in) full height, 16.76 cm (6.6 in) length, 10 W maximum power
(1) PCI Express x16 (v3.0) (wired as a x8): 11.13 cm (4.38) in full height, 16.76 cm (6.6 in) length, 75 W maximum power
(2) PCI Express x1 (v2.0): 6.35 cm (2.5 in) low profile, 16.76 cm (6.6 in) length, 10 W maximum power
(1) PCI Express x16 (v2.0) (wired as a x4): 6.35 cm (2.5 in) low profile, 16.76 cm (6.6 in) length, 10 W maximum power
(1) PCI Express x16 (v3.0) (wired as a x8): 6.35 cm (2.5 in) low profile, 16.76 cm (6.6 in) length, 75 W maximum power
Keyboards/pointing devices
Specification
Keyboards
HP Conferencing keyboard
HP USB PS/2 Washable keyboard
HP USB Smart Card (CCID) keyboard
HP USB Business Slim keyboard
HP PS/2 Business Slim keyboard
HP Grey USB keyboard
Mice
HP PS/2 mouse
HP USB 1000 dpi laser mouse
HP Grey mouse
HP USB mouse
HP USB PS/2 Washable mouse
HP USB mouse (China only)
HP USB Hardened mouse
Combo
HP Wireless Business Slim keyboard and mouse
HP USB keyboard and mouse (China only)
Other
HP mouse pad
Keyboards and pointing devices are optional and must be configured at purchase.
Adapters/cables
Specification
Adapters
HP DisplayPort to DVI-D adapter
HP DisplayPort to DVI-D adapter, 2nd
HP DisplayPort to HDMI 4K adapter
HP DisplayPort to HDMI 4K adapter, 2nd
HP DisplayPort to VGA adapter
HP DisplayPort to VGA adapter, 2nd
Cables
HP DisplayPort cable
HP Display Port cable, 2nd
HP DVI cable (with DisplayPort to DVI Adapter installed)
Adapters and cables are optional and must configured at purchase.
Power supply specifications
Specification
Power supply
Internal
Standard efficiency
70% efficient
Active PFC
HP EliteDesk 705 G3 Microtower Business PC: 280 W
HP EliteDesk 705 G3 Small Form Factor Business PC: 200 W
80 PLUS bronze
82/85/82% efficient at 20/50/100% load (115 V)
82/85/82% efficient at 20/50/100% load (230 V)
Active PFC
80 PLUS platinum
90/92/89% efficient at 20/50/100% load (115 V)
91/93/90% efficient at 20/50/100% load (230 V)
Active PFC
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50/60 Hz
Operating line frequency
47 – 63 Hz
Rated input current
HP EliteDesk 705 G3 Microtower Business PC: 4.4 A
HP EliteDesk 705 G3 Small Form Factor Business PC: 3.5 A
Rated input current with energy efficient power supply
HP EliteDesk 705 G3 Microtower Business PC: 3.6 A
HP EliteDesk 705 G3 Small Form Factor Business PC: 3 A
DC output
12 V
Current leakage (NFPA 99)
Less than 500 microamps of leakage current at 120 VAC with the ground wire disconnected, as required for non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 microamps of leakage current at 120 VAC with the ground wire intact with normal polarity, as required for non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
HP EliteDesk 705 G3 Microtower Business PC: 80 mm variable speed
HP EliteDesk 705 G3 Small Form Factor Business PC: 70 mm variable speed
Power cord length
1.83 m (6 ft)
Physical specifications
Specification
Chassis (W x D x H)
170 x 340 x 355 mm (6.69 x 13.4 x 13.98 in)
Vertical orientation
380 x 338 x 100 mm (14.96 x 13.31 x 3.94 in)
Horizontal orientation
System volume
20.5 L (1252 cu in)
12.8 L (782.7 cu in)
System weight
6.76 kg (14.9 lbs)
6.6 kg (14.55 lbs)
Max supported weight
35 kg (77.16 lbs)
Stand dimensions
178 x 200 x 29 mm (7.01 x 7.87 x 1.14 in)
Packaging (H x W x D)
299 x 517 x 478 mm (11.77 x 20.35 x 18.82 in)
229 x 499 x 528 mm (9.02 x 19.65 x 20.79 in)
Shipping weight
9.78 kg (21.56 lbs)
9.95 kg (21.94 lbs)
Palletization profile
(8) units per layer
(4) layer maximum
(32) units per pallet
(4) units per layer
(10) layer maximum
(40) units per pallet
Weights and dimensions configured with 1 hard disk drive and 1 optical disk drive.
Operating systems
Specification
AMD B350 FCH
Preinstalled (Windows)* **
Windows 10 Pro 64
Preinstalled (other)
FreeDOS 2.0
NeoKylin Linux 64
Web-supported
Windows 10 Pro 64
Windows 10 Enterprise 64
Tested and documented
Windows 7 Professional 64*
*HP intends to test the available Windows 7 Professional drivers and document how they perform. Some device drivers might not be certified by Microsoft.
*This product does not support Windows 8 or Windows 7. In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on this product or provide any Windows 8 or Windows 7 drivers.
**Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
