HP EliteBook 1040 G3 Notebook PC - Specifications
Operating systems
Specification
Preinstalled
Windows 10 Pro 64
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro 64)*
FreeDOS 2.0
*This system is preinstalled with Windows 7 Professional software and also comes with a license and media for Windows 10 Pro software. Only one version of the Windows software can be used at a time. Switching between versions requires you to uninstall one version and install the other version.
Web-only support
Windows 10 Enterprise
Windows 8.1 Enterprise 64
Windows 7 Professional 32
Windows 7 Enterprise 32
Windows 7 Enterprise 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply, and additional requirements might apply over time for updates.
Processors
Specification
Intel Core i7-6600U with Intel HD Graphics 520
2.6 GHz, up to 3.4 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores
Intel Core i7-6500U with Intel HD Graphics 520
2.5 GHz, up to 3.1 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores
Intel Core i5-6300U with Intel HD Graphics 520
2.4 GHz, up to 3 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores
Intel Core i5-6200U with Intel HD Graphics 520
2.3 GHz, up to 2.8 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores
Integrated with processor
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode. Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Graphics
Specification
Integrated
Specification
Non-Touch
35.6 cm (14 in) (diagonal) LED-backlit FHD Anti-glare SVA (1920 x 1080), 300 nits
35.6 cm (14 in) (diagonal) LED-backlit FHD Anti-glare SVA (1920 x 1080), 300 nits with WWAN
35.6 cm (14 in) (diagonal) LED-backlit FHD Anti-glare SVA (1920 x 1080), 300 nits with camera
35.6 cm (14 in) (diagonal) LED-backlit FHD Anti-glare SVA (1920 x 1080), 300 nits with camera and WWAN
35.6 cm (14 in) (diagonal) LED-backlit QHD UWVA (2560 x 1440), 340 nits
35.6 cm (14 in) (diagonal) LED-backlit QHD UWVA (2560 x 1440), 340 nits with WWAN
35.6 cm (14 in) (diagonal) LED-backlit QHD UWVA (2560 x 1440), 340 nits with camera
35.6 cm (14 in) (diagonal) LED-backlit QHD UWVA (2560 x 1440), 340 nits with camera and WWAN
Touch
Touch panel has chemically-strengthened Corning Gorilla Glass 3 top cover.
External
Up to 32-bit per pixel color depth
HDMI
HDMI 1.4 (Cable not included)
UltraSlim docking station
(3) displays supported
Sold separately or as an optional feature.
HD content required to view HD images. Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Specification
Solid state drives
Supports M.2 (NGFF) 2280 Solid State Drive
128 GB SATA-3 TLC SSD
180 GB SATA-3 MLC SSD
180 GB SATA-3 Self-Encrypting Drive (Opal 2) MLC SSD
240 GB SATA-3 MLC SSD
256 GB PCIe-3 x 4 NVMe SSD
256 GB SATA-3 Self-Encrypting Drive (Opal 2) MLC SSD
256 GB SATA-3 TLC SSD
512 GB SATA-3 TLC SSD
For solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and up to 30 GB (for Windows 8.1 and 10) of system disk is reserved for the system recovery software. Internal component upgrades such as storage are not available after factory configuration.
Memory
Specification
Memory
DDR4 PC4 – 2133 (Transfer rates up to 2133 MT/s)
Memory soldered down (No sockets)
Dual channel support
Configuration
8192 MB total system memory (512 MB x 16 MB)
16384 MB total system memory (512 MB x 16 MB x 2)
Maximum
16 GB total system
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Internal component upgrades to memory are not available after factory configuration.
Networking/communication
Specification
Broadband Wireless (WWAN)¹ ²
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP 3110 HSPA+ Mobile Broadband Module
WWAN modules must be preconfigured. WWAN connection requires wireless data service contract, network support, and is not available in all areas. Contact service provider to determine the coverage area and availability. Connection speeds vary due to location, environment, network conditions, and other factors. Not available with Ubuntu.
Wireless LAN (WLAN)¹ ²
Intel Dual Band Wireless-AC 8260 802.11a/b/g/n/ac (2 x 2) WiFi and Bluetooth 4.2 Combo
Communications
Intel Ethernet Connection I218LM 10/100/1000 Ethernet, with iAMT
Near Field Communication (NFC) with Secure Element* ²
*Sold separately or as an option.
¹The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
²NFC is enabled by default on Windows 8.1 and is disabled by default on Windows 7.
Audio/webcam
Specification
Audio
Audio by Bang & Olufsen
(2) Integrated stereo speakers
Integrated dual-microphone array
Button for speaker mute; function keys for volume up and down
Headphone/microphone combo port
Intel Smart Sound Technology (Windows 8.1 and Windows 10)
720p HD webcam
HD format (widescreen)
Videoconferencing and still image capture supported
High quality fixed focus lens
Video capture at resolutions up to 1280 x 720 (720p) and up to 30fps
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Sold separately as an optional feature. HD content required to view HD images.
Keyboards/buttons/function keys
Specification
Keyboard
Spill-resistant with drain
Backlit
HP Dura Keys
Touchpad
ClickPad
Glass with chemical etched surface
Taps enabled as default
Gestures enabled by default
2 Finger scrolling
2 Finger zoom (pinch)
Buttons and function keys
F1 - Sleep
F2 - Blank
F3 - Backlit keyboard
F4 - Display switching
F5 - Brightness down
F6 - Brightness up
F7 - Blank
F8 - Volume down
F9 - Volume up
F10 - Mic mute
F11 - Blank
F12 - Number lock
Security
Specification
Type
Trusted Platform Module (TPM) 1.2 Embedded Security Chip (Common Criteria EAL4+ Certified or FIPS 140-2) (Field upgradeable to TPM 2.0)
Security lock slot (cable not included)
Fingerprint reader
Integrated smart card reader
Power
Specification
Power supply/AC adapters
45W 2-prong AC Adapter
45W Smart AC Adapter
65W Smart EM AC Adapter
65W Slim Travel AC Adapter
Power cord, 1 m (3.28 ft)
Power cord, 1.8 m (5.9 ft), optional
Primary battery
HP 6-Cell (45.6 Whr) polymer long life battery
Battery Life
Up to 11 hours and 30 minutes (With FHD display)
Up to 10 hours (With QHD display)
Windows 10/MM14 battery life varies depending on product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Weight/dimensions
Specification
Starting at 1.43 kg (3.15 lbs) for non-touch
Starting at 1.54 kg (3.40 lbs) for touch
Weight varies by configuration and components.
Dimensions (W x D x H)
Non-Touch
33.7 x 23.45 x 1.58 cm (13.27 x 9.23 x 0.62 in), Front
Touch
33.7 x 23.45 x 1.65 cm (13.27 x 9.23 x 0.65 in), Front
Ports/connectors
Specification
Ports
(2) USB 3.1 Gen 1 charging ports
(1) USB-Type C charging port (15W)
(1) Docking connector
(1) HDMI 1.4
(1) Headphone/microphone combo
(1) Multi-Pin AC port (4.5mm (0.17 in))
Cables not included.
