HP Pavilion x360 15-bk003ds (ENERGY STAR) Product Specifications
X0J71UA
Intel® Pentium® 4405U (2.1 GHz, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
  • Intel® HD Graphics 510 (up to 2.07 GB)
  • Integrated
1 TB 5400 rpm SATA
15.6" diagonal HD SVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style with numeric keypad
Pointing device
802.11ac (1x1) and Bluetooth® 4.0 combo
2 USB 3.0; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.2 x 25 x 2.39 cm
2.29 kg
45 W AC power adapter
3-cell, 48 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP 3D DriveGuard; HP ePrint; HP Games by WildTangent; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink PowerDirector; TripAdvisor
