HP 280 G2 Small Form Factor PC
Specification
Intel H110 chipset
Intel Celeron G3900 with Intel HD Graphics 510
2.8 GHz
2 MB cache
2 cores
Intel Pentium G4400 with Intel HD Graphics 510
3.3 GHz
3 MB cache
2 cores
Intel Core i3-6100 with Intel HD Graphics 530
3.7 GHz
3 MB cache
2 cores
Intel Core i5-6500 with Intel HD Graphics 530
3.2 GHz
6 MB cache
4 cores
Specification
Integrated
Intel Integrated HD Graphics (Vary by processor)
Discrete
NVIDIA GeForce GT 730 2GB PCIe x8 (Optional, selected countries/regions only)
Specification
Form factor
Small form factor
Type
DDR4-2133 (Transfer rates up to 2133 MT/s)
Maximum
32 GB capacity
Number of slots
(2) DIMM
note:For systems configured with more than 3 GB of memory and a 32-bit operating system, all memory may not be available due to system resource requirements. Addressing memory above 4 GB requires a 64-bit operating system. Memory modules support data transfer rates up to 2133 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Specification
Hard drives
500 GB 7200 RPM SATA hard disk drive*
1 TB 7200 RPM SATA hard disk drive*
Solid state drives
128GB SATA Value SSD*
SD card reader
3-in1 SD media card reader
Optical disc drives
HP 9.5mm Desktop G2 Slim DVD-ROM drive
HP 9.5mm Desktop G2 Slim SuperMulti DVD Writer drive
note: |
note:*For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) of system disk is reserved for the system recovery software.
Specification
Type
HD audio with Realtek ALC3252 Audio Codec
Microphone/headphone combo jack
Yes
Line-out and Line-in rear port (3.5mm)
Yes
Specification
Ethernet (RJ-45)
Realtek RTL8111HSH –CG: Integrated 10/100/1000M Gigabit Ethernet Controller supports Wake-on-LAN (WOL).
Wireless
Intel 3168 802.11ac with PCIe x1 WLAN/Bluetooth combo*
Intel 3168 802.11ac with PCIe x1 WLAN/Bluetooth combo disabled*
note: |
Specification
Front in/out ports
(2) USB 3.0 ports
(1) Microphone/headphone combo jack
Rear in/out ports
(6) USB 2.0 ports
(1) RJ45 network connection
(1) Audio line out
(1) Audio line in
(1) VGA
(1) HDMI
Internal in/out ports
(1) PCIe x 16 (3.0)
(1) PCIe x 1 (2.0)
Bays
(1) 3.5 in Hard Disc Drive bay
(1) 9.5 mm Slim Optical Disc Drive bay
1) Secure Digital (SD) Reader bay
Specification
Keyboards
Business Slim USB Antimicrobial Standalone Wired Keyboard
HP USB Business Slim Keyboard
Mice
HP USB Mouse
HP USB Mouse (China only)
note:Keyboards and mice are optional or add-on features.
Specification
Chassis
(H x W x D)
100 x 270 x 290 mm (3.94 x 10.63 x 11.42 in)
3.5 in HDD: 4.03 kg (8.88 lbs)
2.5 in SSD: 3.66 kg (8. 07 lbs)
Specification
Preinstalled Windows
Windows 10 Pro 64
note: |
Pre-installed (other)
FreeDOS 2.0
NeoKylin Linux 64-bit Commercial*
note: |
Web-supported
Windows 10 Pro 64
Specification
Temperature range
Operating: 10° to 35° C (50° to 95° F)*
Non-operating: -30° to 60° C (-22° to 140° F)
note: |
Relative humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
Operating: 3048 m (10,000 ft)
Non-operating: 9144 m (30,000 ft)
Specification
Type
Trusted Platform Module (TPM) 2.0 (Firmware)
Security cable slot
