    Apache Log4j Update
HP Pavilion - 15-au113tx Product Specifications
Y4F76PA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Pointing device
WiDi; Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 3.0; 1 USB 2.0; 1 RJ-45
38.3 x 24.3 x 2.25 cm
2 kg
65 W EM AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY
HP 3D DriveGuard; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Buy Office
