Document ID: c05226582
Version: 1
Advisory: HP Spectre Pro X360 G2 Convertible PC - Auto-Rotate Does Not Work in Windows 7
Release date : 04-Aug-2016
Last updated : 05-Aug-2016
DESCRIPTION
The auto-rotate feature does not work on computers running Windows 7. This is due to a limitation of the operating system.
sourceInformation
SCOPE
Computers:
HP Spectre Pro x360 G2 Convertible PC
Operating Systems:
Microsoft Windows 7
RESOLUTION
The auto-rotate feature is not supported by Windows 7 (it is supported in Windows 8 and Windows 10).
HP has developed a utility (HP System Event Utility) that provides the necessary support. Install the following two SoftPaqs to enable auto-rotation in Windows 7:
SoftPaq Description
Release Notes
Download SoftPaq
Version: 1.40
Revision: A
SoftPaq Description
Release Notes
Download SoftPaq
Intel Integrated Sensor Solution Driver
Version: 3.0.20.3157
Revision: A
Hardware platforms affected : HP Spectre Pro x360 G2 Convertible PC
Support Communication Cross Reference ID : IA05226582
Country: Flag Vietnam
