    Windows 11 Upgrade Guide
HP Spectre x360 - 15-ap004nf (ENERGY STAR) Product Specifications
W6X74EA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB LPDDR3-1600 SDRAM (onboard)
Video graphics
  • Intel® HD Graphics 520
  • Integrated
256 GB M.2 SSD
39.6 cm (15.6") diagonal UHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (3840 x 2160)
Keyboard
Full-size island-style backlit keyboard
Pointing device
802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 3 USB 3.0 (HP USB Boost); 1 USB 3.0 (Type-C™, HP USB Boost); 1 Mini DisplayPort
37.8 x 24.7 x 1.6 cm
1.82 kg
45 W AC power adapter
3-cell, 64.5 Wh Li-ion
HP TrueVision Full HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen; Quad speakers
HP Lounge
Pre-installed software
Netflix
