    Windows 11 Upgrade Guide
HP Spectre x360 - 13-4104ur (ENERGY STAR) Product Specifications
X5B58EA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB LPDDR3-1600 SDRAM (onboard)
Video graphics
Intel® HD Graphics 520
256 GB PCIe® NVMe™ M.2 SSD
33.8 cm (13.3") diagonal FHD IPS LED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit
Pointing device
Intel 802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 3 USB 3.0 (HP USB Boost); 1 Mini DisplayPort
32.5 x 21.8 x 1.6 cm
1.45 kg
45 W AC power adapter
3-cell, 56 Wh Li-ion
HP TrueVision Full HD WVA Webcam (front-facing) with integrated dual digital microphones
Bang & Olufsen; Dual speakers
HP Lounge
Pre-installed software
Skype
