    Windows 11 Upgrade Guide
HP Pavilion 15-bc015tx Product Specifications
X1G84PA
Intel® Core™ i7-6700HQ (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
Intel HM170
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 960M (2 GB GDDR5 dedicated)
  • 1 TB 7200 rpm SATA
  • 128 GB M.2 SSD
15.6" diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.2 x 25.3 x 2.45 cm
Starting at 2.1 kg
120 W AC power adapter
3-cell, 61.5 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Documentation
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; Dropbox; TripAdvisor
