HP Elite x3 - Using Dual SIMs (Windows 10 Mobile)
This document is for the HP Elite x3 with Windows 10 Mobile.
The HP Elite x3 comes with dual SIM capability, which allows you the option to have two separate lines (one business and one personal, for example) on the same phone. Use this document to learn about using the dual SIM technology on your HP Elite x3.
