    Windows 11 Upgrade Guide
HP LaserJet Pro, Ultra Printers - 'Black Cartridge is Low' Message
This document is for HP LaserJet Pro MFP M130fn, M130fw, M130nw, M132fn, M132fp, M132fw, M132nw, M132snw, M227d, M227fdn, M227fdw, M227sdn, and LaserJet Ultra MFP M134fn and M230sdn printers.
A Black Cartridge is Low or Very Low message displays when the amount of toner in the cartridge is below a certain percentage. This message is a reminder to have a replacement toner cartridge available. You do not need to replace the toner cartridge until print quality becomes unacceptable.
You can change when the Black Cartridge is Low message displays by changing your Supply Settings options in the System Setup menu on the printer control panel.
Purchase a replacement toner cartridge
