    Apache Log4j Update
HP Pavilion 17-ab008no (ENERGY STAR) Product Specifications
Y0C20EA
Intel® Core™ i7-6700HQ (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
Intel HM170
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
  • NVIDIA® GeForce® GTX 960M (2 GB GDDR5 dedicated)
  • Discrete
1 TB 7200 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
41.6 x 27.9 x 2.99 cm
2.85 kg
120 W AC power adapter
6-cell, 62 Wh Li-ion
Battery type note
User-replaceable battery
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
HP CoolSense; HP Lounge
Pre-installed software
CyberLink PowerDirector; Netflix
1 month trial for new Microsoft® Office 365 customers
