HP Notebook - 15-ay078nr (ENERGY STAR) Product Specifications
X0H77UA
Intel® Core™ i7-6500U (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
6 GB DDR3L-1600 SDRAM (1 x 2 GB, 1 x 4 GB)
Video graphics
  • Intel® HD Graphics 520 (up to 3.07 GB)
  • Integrated
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style with numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.43 x 25.46 x 2.43 cm
2.14 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP ePrint; HP Games by WildTangent; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink Power Media Player; CyberLink PowerDirector; TripAdvisor
