HP Pavilion 15-aw003cy (Touch) (ENERGY STAR) Product Specifications
X3T13UA
AMD Dual-Core A9-9410 APU (2.9 GHz, up to 3.5 GHz, 1 MB cache)
6 GB DDR4-2133 SDRAM (1 x 2 GB, 1 x 4 GB)
Video graphics
  • AMD Radeon™ R5 Graphics
  • Integrated
  • 1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA WLED-backlit touch screen (1366 x 768)
Keyboard
Full-size island-style with numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
1 USB 2.0; 2 USB 3.0; 1 HDMI; 1 headphone/microphone combo
38.2 x 24.2 x 2.25 cm
2.06 kg
45 W AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY with 2 speakers
HP 3D DriveGuard; HP ePrint; HP Games by WildTangent; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink Power Media Player; CyberLink PowerDirector; TripAdvisor
