Model name
HP OfficeJet 250 Mobile All-in-One Printer
CZ992A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP OfficeJet 252 Mobile All-in-One Printer (N4L16C)
Product naming
What's included and accessories
What's in the box
HP OfficeJet 250 Mobile All-in-One Printer; HP 651 Black Original Ink Advantage Cartridge; HP 651 Tri-color Original Advantage Ink Cartridge; Software CD; Setup Poster; Power Cord; Battery
Accessories
M9L89A HP OfficeJet 200 series Battery
Connectivity
Connectivity, standard
1 USB 2.0 device; 1 USB 2.0 host; 1 HP wireless direct; 1 Bluetooth low energy (LE)
Wireless capability
Yes. Wireless, wireless direct, and Bluetooth low energy (LE)
Copy
Copier settings
Legal to Letter; A4 to Letter; Letter to A4
Color copy capability
Yes
Maximum number of copies
Up to 50 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
On AC: up to 18 ppm; On Battery: up to 17 ppm
Copy speed, black (draft, Letter)
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions
5.7 B(A) (Best); 6.0 B(A) (Normal); 6.2 B(A) (Fast Draft)
Operating humidity range
20 to 80% RH
Storage humidity
5 to 90% RH
Recommended operating temperature range (Celsius)
15 to 30ºC
Recommended operating temperature range (Fahrenheit)
59 to 86ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Memory
Memory card compatibility
None
Mobile printing capability
Yes
Mobile printing services
Apple AirPrint™; HP ePrint; Wireless (WiFi); USB; HP wireless direct printing
Networking
Network protocols, supported
Wi-Fi network support
Paper handling
Input capacity
Up to 50
Standard input capacity (cards)
Up to 20
Standard input capacity (envelopes)
Up to 5
Standard input capacity (transparencies)
Up to 5
Media sizes supported (metric)
A4; A5 ; A6; B5 (ISO); B5 (JIS);envelopes (A2; C5; C6; DL); photo (10 x 15 cm; L; 2L); Japanese Postcard; Ofuku Hagaki
Media sizes supported (U.S. standard)
Letter, Legal, Statement, Executive, envelopes (No. 10, Monarch, 6 3/4 in), cards (3 x 5 in, 4 x 6 in, 5 x 8 in), photo (8 x 10 in, 5 x 7 in, 4 x 6 in, 3.5 x 5 in)
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers; Plain Paper, Light/Recycled
Media weight supported (metric)
60 to 300 g/m²
Media weight supported (U.S. standard)
16 to 32 lb (plain paper); 20 to 55 lb (envelope); up to 110 lb (cards)
Duplex options
Manual (driver support provided)
Paper handling - ADF
Automatic document feeder capacity
Up to 10
Physical dimensions
Maximum dimensions (W x D x H, metric)
380.2 x 401.5 x 269.8 mm (Scan + Print Tray opened)
Maximum dimensions (W x D x H, U.S. standard)
14.97 x 15.8 x 10.6 in (Scan + Print Tray opened)
Weight (metric)
2.96 kg (3.06 kg with Battery)
Weight (U.S. standard)
6.51 lb (6.73 lb with Battery)
Power
Energy savings feature technology
HP Auto-Off Technology
Built-in universal power supply
Power supply
Input voltage: 100 to 240 VAC, 50 to 60 Hz; 200 to 240 VAC, 50 to 60 Hz
Power consumption
0.14 watts (Manual-Off), 3.4 watts (Standby), 0.81 watts (Sleep)
Rechargeable ithium ion battery pack
Battery charging voltage
12.45 V
Battery capacity
1050 mAh 12Wh
Battery life
Up to 225 ISO pages on full charge
Print cartridges
Number of print cartridges
2: 1 black, 1 color (cyan, magenta, yellow)
Replacement cartridges
Printing specifications
Print technology
HP Thermal Inkjet
Print speed (black, draft, Letter)
On AC: up to 20 ppm; On Battery: up to 18 ppm
Print speed (color, draft, Letter)
On AC: up to 19 ppm; On Battery: up to 17 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer and 1200 input dpi)
Maximum print area (metric)
209.9 x 349.6 mm
Maximum print area (U.S. standard)
8.3 x 13.8 mm
Monthly duty cycle
Up to 500 pages
Print languages
HP PCL 3 GUI
Printer smart features
Automatic paper width sensing; Paper presence sensor; Articulating control panel; Battery indicator; Phone charging from USB; Printer charging from USB host port (requires standard USB cable, printer charges from charging port and in OFF mode)
Regulatory specifications
Regulatory model number
SNPRC-1604-01
Energy efficiency
ENERGY STAR® qualified
Safety
EN 60950/IEC 60950 Compliance (International); safety cCSAus (USA/Canada); GS approved; Russia EAC; China CCC; Taiwan BSMI; Australia/New Zealand RCM
Electromagnetic compatibility
EU (EMC Directive), USA (FCC Rules), Australia/New Zealand (RCM), Canada (ICES), China (CCC), Japan (VCCI registered), Korea (KC certified), Taiwan (BSMI certified)
Scan
Scanner advanced features
10-page Automatic Document Feeder (ADF)
Scan technology
CIS
Scan speed (normal)
Up to 9 ppm black/white or greyscale; up to 3.6 ppm color
Scan resolution, hardware
Up to 600 x 600 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum ADF scan size (metric)
216 x 356 mm
Maximum ADF scan size (U.S. standard)
8.5 x 14 in
Twain version
Version 1.9
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows Vista: (32-bit only), 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Apple OS X v10.11 El Capitan, OS X v10.10 Yosemite, OS X v10.9 Mavericks; 1 GB HD; Internet required; USB. Linux, see http://hplipopensource.com/hplip-web/index.html.
Recommended system requirements for Windows
Minimum system requirements for Macintosh
Apple® OS X v10.11 El Capitan, OS X v10.10 Yosemite, OS X v10.9 Mavericks; 1 GB HD; Internet required; USB
Recommended Macintosh system requirements
Compatible network operating systems
One-year limited hardware warranty
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
