Remove and Replace the Memory Modules on HP ProBook 640 and 645 G2 Notebooks
This document applies to HP ProBook 640 and 645 G2 notebooks.
HP ProBook 64x G2 notebook
Before you begin
  • Have available a small, Phillips-head (P1) screwdriver and small, flat-bladed screwdriver or a flat-bladed alignment/pry tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing and replacing parts and servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of the notebook. These same removal and replacement procedures apply to all configurations of HP ProBook 640 and 645 G2 notebooks.
Removing the memory modules
Use the steps in this section to remove the memory modules.
The computer might have one memory module or two. The instructions are the same.
Step 1
Remove the bottom cover.
The bottom cover
Step 2
Remove the battery.
The battery
Step 3
Push both arms outward simultaneously to release the memory module to the spring tension position.
When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
Pushing the retention arms out to release the memory module
Step 4
Grasp the memory module by the edges and pull gently to remove it.
Grasping the memory to pull it out
Step 5
Place the memory module in a static dissipative bag.
Placing the memory module in a static dissipative bag
Replacing the memory modules
Use the steps in this section to replace the memory modules.
Step 1
Grasp the memory module by the edges and remove it from the static dissipative bag.
Grasping the memory module by the edges and removing it from the bag
Step 2
Align the notch in the memory module with the key in the memory module slot on the system board.
Aligning the notch in the memory module with the key in slot on the system board
Step 3
At an angle, gently insert the memory module into its slot on the system board.
 Insert the memory module
Step 4
Press the memory module down to latch the arms. The clips will snap into place and hold the memory module in place.
Pressing the memory module down
Step 5
Replace the battery.
The battery
Step 6
Replace the bottom cover.
The bottom cover
