HP Notebook - 17-x003nf (ENERGY STAR) Product Specifications
E8N69EA
Intel® Pentium® N3710 (1.6 GHz, up to 2.56 GHz, 2 MB cache, 4 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
AMD Radeon™ R5 M430 Graphics (2 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD+ SVA BrightView WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
41.7 x 27.9 x 2.49 cm
2.75 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP Lounge
Pre-installed software
CyberLink PowerDirector; Netflix
