HP Pavilion Notebook - 17-g151na (ENERGY STAR) Product Specifications
N9S40EA
AMD Quad-Core A8-7410 APU with Radeon™ R5 Graphics (2.2 GHz, up to 2.5 GHz, 2 MB cache)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video Graphics
AMD Radeon R5 Graphics
Hard Drive
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD+ BrightView WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
41.88 x 28.68 x 2.71 cm
2.79 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
