    Looking for Site Help?
HP PageWide Enterprise Color MFP 586 - Clear jams in Tray 3 (accessory)
Use the following procedure to check for paper in all possible jam locations related to Tray 3. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. Open the lower-left door.
    Figure : Open the jam-access door
  2. Gently pull out any jammed paper.
  3. Close the lower-left door.
    Figure : Close the jam-access door
  4. Pull the tray completely out of the printer by pulling and lifting it up slightly.
    Figure : Open the tray
  5. Remove any jammed or damaged sheets of paper. Verify that the tray is not overfilled and that the paper guides are adjusted correctly.
    Figure : Remove any damaged paper
  6. Remove any paper from the feed rollers inside the printer. First pull the paper to the right to release it, and then pull it forward to remove it.
    Figure : Remove the jammed paper
  7. Reinsert and close the tray.
    Figure : Close the tray
Country: Flag Vietnam
