HP LaserJet Pro - Troubleshoot 55.xx (NVRAM) messages
This document provides information about how to resolve common error messages related to non-volatile RAM (NVRAM). It does not contain all of the possible error codes for HP LaserJet Pro printers.
The following table lists common control panel messages and event codes for HP LaserJet printers. It also lists descriptions of the codes and the actions recommend to resolve the errors.
Event code
Recommended action
55.0005
Hardware memory error (DC controller)
The engine control PCA needs to be replaced. Contact HP support: www.hp.com/go/support
55.0601
DC controller NVRAM data error
Turn the printer off, and on again.
If the error persists, the engine control PCA needs to be replaced. Contact HP support: www.hp.com/go/support
55.0602
DC controller NVRAM access error
55.0901
Page counts stored in NVRAM were requested to be reset. Special access is required to change this setting.
No action is necessary.
55.0902
Page counts stored in NVRAM were reset. Special access is required to change this setting.
55.0903
Protected NVRAM engine interface variables (group 1, which includes page counts) were reset (by Super NVRAM INIT or another operation). Special access is required to change this setting.
55.0904
Protected NVRAM engine interface variables (group 2) were reinitialized (by Super NVRAM INIT or another operation). Special access is required to change this setting.
55.1000
DC controller memory error
55.3000
Engine/ formatter communication error
If the error persists, the cable that connects the engine control PCA to the formatter might be loose or damaged. Contact HP support: www.hp.com/go/support
55.4000
Engine communication timeout error
After restarting, a 55.3000 error might occur. The problem could be the cable that connects the engine control PCA to the formatter, or it could be the engine control PCA, or the formatter. Contact HP support: www.hp.com/go/support
55.9028
DC controller NVRAM restore
This is an informational message for the service person. This message indicates that the formatter successfully restored the data to the engine control PCA.
