HP ENVY 5646 e-All-in-One Printer (F8B05A) Specifications
Product Naming
Product description
HP ENVY 5646 e-All-in-One Printer F8B05A
Connectivity
Direct print supported
Wireless direct printing; Memory card slot
Connectivity, standard
1 USB 2.0; 1 Wi-Fi 802.11b/g/n
Wireless capability
Yes
Copy
Copy speed black (draft, A4)
Up to 21 cpm
Copy speed color (draft, A4)
Up to 19 cpm
Copier settings
Number of Copies; 2-Sided; Draft; Black; Color; Quality; Resize; Lighter/Darker; Paper Size; Paper Type; Margin Shift; Enhancements; Set as New Defaults
Copies, maximum
Up to 50 copies
Color copy capability
Yes
Copy reduce / enlarge settings
25 to 400%
Environmental
Operating humidity range
20 to 80% RH
Storage temperature range
-40 to 60º C (-40 to 140º F)
Recommended operating temperature range
5 to 35º C (41 to 95º F)
Acoustic power emissions
6.4 B(A) (printing at 6 PPM)
Storage humidity
10 to 90% RH (non condensing)
Environmental specifications
Save paper by up to 50% using automatic two-sided printing. Free, convenient cartridge recycling in 48 countries. http://www.hp.com/recycle
Fax
Faxing
No
Ink Cartridges/Toner Cartridges
SureSupply note
HP SureSupply alerts you when you should replace a print cartridge and helps you purchase locally or via the Internet. For more information, visit http://www.hp.com/learn/suresupply. Only available with original HP supplies; Internet access required.
Replacement cartridges
HP 62 Black Ink Cartridge (~200 pages); HP 62 Tri-color Ink Cartridge (~165 pages); HP 62XL Black Ink Cartridge (~600 pages); HP 62XL Tri-color Ink Cartridge (~415 pages). [Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. For details see hp.com/go/learnaboutsupplies][6]
Replacement cartridges footnote
[6] Approximate yield. Actual yield depends on printer and specific use. See hp.com/go/pageyield for more information.
Number of print cartridges
2 (1 black, 1 Tri-color [cyan, magenta, yellow])
Memory device
Memory card compatibility
Secure Digital
Mobile Printing Capability
Mobile printing capability
Features Wi-Fi Direct and local Wi-Fi connectivity to enable mobile printing via HP ePrint, Apple AirPrint™ as well as other solutions. Supports printing from most smartphones and tablets using these operating systems: Android, iOS, Blackberry, Windows 8, Windows RT.[3]
Mobile printing compatibility note
[3] Wireless performance is dependent upon physical environment and distance from the access point. Wireless operations are compatible with 2.4 GHz routers only; excludes wireless direct. Wireless direct may require driver or apps be installed and connected on wireless-enabled mobile device or PC. Wireless functionality may vary by computer and mobile operating systems, see hpconnected.com. HP ePrint requires: account registration, HP ePrint-enabled printer, Internet connection, and a wireless-enabled mobile device or Internet-connected computer with email capability. Separately purchased data plans or usage fees may apply. Print times and connection speeds may vary. AirPrint supports OS X® Lion, OS X® Mountain Lion and the following devices running iOS 4.2 or later: iPad®, iPhone® (3GS or later), iPod touch® (3rd generation or later) and requires the printer be connected to the same network as your OS X or iOS device. AirPrint, the AirPrint Logo, iPad, iPhone, and iPod touch are trademarks of Apple® Inc. Windows® is a trademark of the Microsoft group of companies. BlackBerry® names and logos are the property of Research In Motion Limited. Android is a trademark of Google Inc.
Network Protocol
Network protocols, supported
TCP/IP
Paper Handling
Media sizes supported (U.S. standard)
Letter, Legal, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Media weight, supported (metric)
Tray 1: A4: 75 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP Photo Paper: up to 250 g/m²; HP 10 x 15 cm photo paper: up to 250 g/m²
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media weight, supported (U.S. standard)
16 to 72 lb
Duplex options
Automatic
Maximum print area
209.9 x 349.6 mm (8.3 x 13.8 in)
Standard input capacity (secondary tray)
Up to 15 sheets
Envelope input capacity
Up to 5 envelopes
Input capacity
Up to 125 sheets
Standard input capacity (envelopes)
Up to 5
Output capacity
Up to 25 sheets
Standard input capacity (Legal)
Up to 125 sheets
Standard input capacity (cards)
Up to 40 cards
Standard input capacity (transparencies)
Up to 40 sheets
Paper handling - ADF
Media sizes, custom
76 x 127 to 216 x 356 mm (3 x 5 to 8.5 x 14 in)
Paper Handling - Duplexer
Duplexer media sizes
Letter; Executive [all media lengths between 140 and 310 mm (5.5 and 12.2 in)]
Physical Dimensions
Maximum dimensions (W x D x H)
454 x 503 x 161 mm (17.9 x 19.8 x 6.3 in)
Power
Power consumption
13.95 watts (printing), 3.60 watts (ready), 0.93 watts (sleep), 0.20 watts (off)
Built-in Universal Power Supply
Power supply
100-240 V (+/-10%), 50/60 Hz (+/- 3 Hz)
Energy savings feature technology
HP Auto-Off Technology
Printing Specifications
Print technology
HP Thermal Inkjet
Print languages
HP PCL 3 GUI
Duty cycle (monthly, Letter)
Up to 1000 pages
Print speed color (ISO)
Up to 8 ppm
Print speed color (draft, Letter)
Up to 21 ppm
Print speed black (ISO)
Up to 12 ppm
Print speed black (draft, Letter)
Up to 22 ppm
Print quality color (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer with 1200 input DPI on selected HP photo papers and Print in Max DPI)
Print quality black (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Regulatory Specifications
Safety
IEC 60950 -1: 2005+ A1:2009/EN 60950-1: 2006+A11: 2009 +A1:2010 +A12:2011; IEC 62479:2010/EN 62479:2010; IEC 62311: 2007/EN 62311: 2008; Australia/New Zealand AS/NZS 60950.1: 2011; Canada/America CAN/CSA-C22.2 No 60950-1-07, Amendment 1:2011, Low Voltage Directive 2006/95/EC with CE Marking (Europe); Singapore PSB; Korea KCC; Taiwan BSMI; Other safety approvals as required by individual countries.
Electromagnetic compatibility
CISPR 22:2008 / EN 55022:2010 (Class B), CISPR24:2010/EN 55024:2010, EN 301 489-1 v1.9.2: 2011, EN 301 489-17 v2.2.1: 2012, EN 61000-3-2 :2006 +A1:2009 +A2:2009, EN 61000-3-3: 2008, EMC Directive 2004/108/EC with CE Marking (Europe), FCC Part 15 Rules Class B (USA), ICES-003 Issue 5 (Canada), EN 55022:2006 (Australia/New Zealand), VCCI V-3 2013.04 (Japan), KKC certified (Korea), CNS 13438:2006 (Taiwan BSMI)
Energy efficiency
ENERGY STAR® qualified
Regulatory model number
SDGOB-1401-01
Scan
Scan resolution, hardware
Up to 1200 x 1200 dpi
Scan size (flatbed), maximum
216 x 297 mm (8.5 x 11.7 in)
Twain version
Version 1.9
Scan technology
CIS
Scanning options (ADF)
Not Supported
Levels of grayscale
256
System Requirements
Recommended system requirements
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows Vista: 800 MHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows XP SP3 or higher (32-bit only): any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 800 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 6.
Minimum system requirements
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows Vista: 800 MHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Minimum system requirements for Macintosh
OS X v10.7 Lion, OS X v10.8 Mountain Lion, OS X v10.9 Mavericks, 1 GB HD Internet, USB
Recommended Macintosh system requirements
Mac OS X Lion, OS X Mountain Lion, OS X Mavericks; Intel® Core™ Processor; 1 GB HD; CD-ROM/DVD or Internet; USB
