HP EliteBook Folio G1 Notebook PC - Specifications
Feature
Preinstalled
Windows 10 Pro 64
Web-only support
Windows 10 Enterprise 64
Windows 8.1 Enterprise 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 7 Professional 32
Windows 7 Professional 64
Windows 7 Enterprise 64
Windows 7 Enterprise 32
Processors
Feature
Intel Core m7-6Y75 with Intel HD Graphics 515
1.2 GHz, up to 3.1 GHz with Intel Turbo Boost Technology
4 MB cache
2 cores
Intel Core m5-6Y57 with Intel HD Graphics 515
1.1 GHz, up to 2.8 GHz with Intel Turbo Boost Technology
4 MB cache
2 cores
Intel Core m5-6Y54 with Intel HD Graphics 515
1.1 GHz, up to 2.7 GHz with Intel Turbo Boost Technology
3 MB cache
2 cores
Intel Core m3-6Y30 with Intel HD Graphics 515
900 MHz, up to 2.2 GHz with Intel Turbo Boost Technology
3 MB cache
2 cores
Graphics
Feature
Integrated
Feature
Internal
Non-touch
12.5 in diagonal FHD UWVA ultra slim LED-backlit (1920 x 1080)
12.5 in diagonal FHD UWVA anti-glare ultra slim LED-backlit (1920 x 1080) Light weight
Touch
12.5 in diagonal FHD UWVA ultra slim LED-backlit (1920 x 1080) Touch
12.5 in diagonal UHD UWVA ultra-slim LED-backlit (3840 x 2160) Touch
Optional docking solution
HP Elite Thunderbolt 3 Dock
HP Executive Travel Hub
Storage and drives
Feature
Solid State Drives
128 GB SATA-3 SS TLC
512 GB SATA-3 SS TLC
240 GB SATA-3 SS MLC
256 GB PCIe Gen3x4 SS NVMe SS MLC
256 GB SATA-3 SS MLC (Opal 2)
Primary storage bay
Supports M.2 SS 2280 Solid State Drives
Memory
Feature
Standard
LPDDR3 1866 (Transfer rates up to 1866 MT/s.)
Memory soldered down
Supports Dual Channel Memory
8 GB LPDDR3-1866 SDRAM
Maximum
8 GB
Networking/communication
Feature
Wireless LAN (WLAN)
Intel 802.11a/b/g/n/ac (2 x 2) and Bluetooth 4.2 Combo
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
Integrated dual-array microphone
4 Integrated premium stereo speakers
Webcam (optional)
720p resolution
Keyboard
Feature
Keyboard
Backlit
HP DuraKeys
Pointing device
Glass ClickPad
Taps enabled as default
Gestures enabled by default
On/Off LED
Buttons and function keys
F1 - Call Answer
F2 - Call Decline / End
F3 - Calendar
F4 - Mic mute
F5 - Speaker Mute
F6 - Vol Down
F7 - Vol Up
F8 - Display Switch
F9 - Backlight Keyboard
F10 - Bright Down
F11 - Bright Up
F12 - Wireless On/Off
Software and security
Feature
BIOS
HP BIOSphere
HP Sure Start with Dynamic Protection
HP DriveLock
HP Automatic DriveLock
HP BIOS Protection
BIOS Update via network
Master Boot Record Security
Power-on Authentication
HP SpareKey
Pre-Boot Security
Secure Erase
Hybrid Boot
Measured Boot
Secure Boot
Absolute Persistence Module
Pre-boot Authentication
Multimedia
Cyberlink PowerDVD, BD
Cyberlink Power2Go (Secure Burn)
Communication
HP GPS and Location (Windows 7 only)
HP Connection Manager with support for HP Mobile Connect Pro (Windows 7 only)
HP Mobile Connect Pro (Windows 8.1 and Windows 10 only)
Intel Wireless Display (WiDi) Software for Windows
Native Miracast Support
HP Value Add software
HP 3D DriveGuard
HP ePrint driver
HP Hotkey
HP Recovery Manager
HP Recovery Disc Creator
HP Registration App (Windows 8.1 only)
HP Support Assistant
HP Noise Reduction Software
3rd party
Foxit PhantomPDF Express for HP
Microsoft products
Buy Office
Bing Search
Skype
Manageability
HP Driver Packs
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)
HP BIOS Config Utility (BCU)
HP Client Catalog
HP CIK for Microsoft SCCM
LANDESK Management
HP Image Assistant
Client security software
HP Drive Encryption
HP Client Security
  • HP Security Manager (including Credential Manager and Password Manager)
  • HP Drive Lock
  • HP Fingerprint Sensor
  • HP Password Manager
  • Absolute Persistence Module
  • Power On Authentication
Microsoft Security Essentials
Microsoft Defender
Security
TPM 1.2/2.0 (Infineon, soldered down)
Common criteria EAL4+ certified
Power
Feature
Power supply
HP 45 W Smart USB Type-C AC adapter
Power cord included is 1.8 m (+/- 0.1 m) or 1.0 m (+/- 0.1 m)
Primary battery
HP Long Life 4-cell, 38 WHr Li-ion polymer
Battery life
Up to 10 hours
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Weight and dimensions
Feature
Non-touch
1 kg (2.09 lb)
Lightest panel, 38 WHr battery, 8 GB, 128 GB SSD, RGB Camera, WLAN + Bluetooth
Touch
1.09 kg (2.41 lb)
Lightest panel (with touch), 38 WHr battery, 8 GB, 128 GB SSD, RGB Camera, WLAN + Bluetooth
Dimensions (W x D x H)
Non-touch
29.2 x 20.9 x 1.24 cm (11.5 x 8.23 x 0.49 in)
Touch
Ports
Feature
Ports
(2) USB Type-C ports with Thunderbolt support (docking, charging and USB 3.1)
(1) Headphone / Microphone combo jack
(1) Power connector
(1) Ethernet via accessory dongle (optional)
