    Apache Log4j Update
HP LaserJet Enterprise MFP M527, HP LaserJet Managed MFP E52545 - Removal and replacement: Staple cartridge
M527c/f/z printers only.
This document provides the procedures to remove and replace the staple cartridge.
Before performing service
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Staple cartridge part number
Q7432A
HP staple cartridge pack
Required tools
  • No special tools are required to remove this part.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Make sure that the printer initializes to a Ready state.
Print a configuration page to make sure that the printer is functioning correctly.
Step 1: Remove the staple cartridge
  1. Open the stapler door.
    Figure : Open the stapler door
  2. Pull the staple cartridge straight out of the printer to remove it.
    Figure : Remove the staple cartridge
Step 3: Unpack the replacement staple cartridge
Unpack the replacement part from the packaging.
Recycle and unpack
Figure : Recycle and unpack
Step 3: Install the staple cartridge
  1. Push the staple cartridge straight into the printer to install it.
    Figure : Install the staple cartridge
  2. Close the stapler door.
    Figure : Close the stapler door
