    Apache Log4j Update
HP LaserJet Enterprise MFP M527, HP LaserJet Managed MFP E50045, E52545 - Install accessory: Internal USB ports
This document provides the procedures to remove and replace the internal USB ports.
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
    To avoid damage to the printer, turn the printer off, wait 30 seconds, and then remove the power cord before attempting to service the printer.
This part contains components that are electrostatic discharge (ESD) sensitive. To reduce the possibility of ESD damage, always touch the sheet-metal chassis to ground yourself before touching an ESD sensitive part.
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Internal USB ports part number
F2A87A
Internal USB ports (M527)
Required tools
No special tools are required to install this part.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Make sure that the printer initializes to a Ready state.
Print a configuration page to make sure that the printer is functioning correctly.
Step 1: Remove the formatter cover
  1. Slide the cover toward the rear of the printer to remove it.
    Figure : Remove the formatter cover
Step 2: Remove the fax (M527c/f/z)
This step is for the M527c/f/z printers. For the N527dn model, skip this step and go to Step3: Unpack the accessory.
ESD-sensitive part.
M527c/f/z printers only (optional for the M527dn).
  1. Disconnect three connectors (callout 1).
    Figure : Disconnect three connectors
  2. Pinch the retainer to release it.
    Figure : Release the fax PCA
  3. Rotate the connector end of the fax PCA out and away from the formatter (callout 1), and then slide it as shown (callout 2) to remove it.
    Figure : Remove the fax PCA
Remove the new part from its package. Save all packaging for recycling.
For complete information on HP's recycling programs, go to Product return and recycling.
Recycle and unpack
Figure : Recycle and unpack
Step 4: Install the internal USB ports module
ESD-sensitive part.
  1. Position the notches on the internal USB ports PCA over the clips on the PCA holder and press down to attach the PCA to the holder. Make sure that the clips snap into place.
    Figure : Install the PCA in the holder
  2. Connect the wire harness to the PCA.
    Figure : Connect one cable
  3. Position the PCA and bracket in the printer with the top tab aligned with the top slot (callout 1), and bottom edge of the bracket aligned with the bottom slot (callout 2).
    When correctly installed, the PCA and bracket are firmly held in place.
    Figure : Position the internal USB ports module
  4. Sled the PCA and bracket to the left until the tab on the bottom edge snaps into place.
    Figure : Install the internal USB ports module
  5. Pass the wire harness through the provided opening in the chassis.
    Figure : Install the wire harness
  6. Connect one connector on the formatter.
    Figure : Connect one connector
Step 5: Install the fax (M527c/f/z)
This step is for the M527c/f/z printers. For the N527dn model, skip this step and go to Step 6: Install the formatter cover.
ESD-sensitive part.
  1. Before proceeding, take note of the location of the slots (callout 1) in the sheet-metal where the fax PCA cradle mounting tab and fax port (callout 2) must be installed.
    Figure : Locate the slots in the sheet-metal
  2. Insert the fax PCA cradle mounting tab and fax port in the slots in the sheet-metal plate (callout 1), and then rotate the connector end of the fax PCA toward the formatter (callout 2).
    Figure : Install the fax PCA
  3. Engage the retainer with the slot in the formatter.
    Pinch the retainer to easily engage it with the slot.
    Figure : Engage the fax PCA
  4. Connect three connectors (callout 1).
    Figure : Connect three connectors
  1. Slide it toward the front of the printer to install it.
    Figure : Install the formatter cover
