HP ENVY Notebook - 17-s066nr (Touch) (ENERGY STAR) Product Specifications
P4W30UA
Intel® Core™ i7-6500U (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
16 GB DDR3L-1600 SDRAM (2 x 8 GB)
Video Graphics
NVIDIA GeForce 940M (2 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
17.3" diagonal FHD IPS LED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Wireless Connectivity
802.11ac (1x1) and Bluetooth® 4.0 combo
External Ports
2 USB 3.0; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
41.88 x 28.68 x 2.71 cm
3.14 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen with 2 speakers
HP Support Assistant; HP Recovery Manager; HP ePrint; HP Connected Photo; HP 3D DriveGuard; HP CoolSense
Buy Office
Pre-installed software
TripAdvisor; Dropbox; Netflix; CyberLink PhotoDirector; CyberLink PowerDirector; CyberLink Power Media Player; CyberLink YouCam; Evernote Premium
