HP Spectre Pro x360 G2 Convertible PC - Specifications
Operating systems
Feature
Preinstalled
Windows 10 Pro 64
Web-only support
Windows 10 Pro 64
Windows 10 Enterprise 64
Windows 8.1 64
Windows 8.1 Professional 64
Windows 8.1 Chinese Market 64
Windows 8.1 Emerging Markets 64
Windows 8.1 Multi-Language 64
Windows 7 Enterprise 64
Windows 7 Professional 64
Processors
Feature
Integrated with processor
Intel Core i7-6600U with Intel HD Graphics 520 (Available with iAMT (vPro))
2.6 GHz, up to 3.2 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores
Intel Core i5-6300U with Intel HD Graphics 520
2.3 GHz, up to 2.9 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores
Intel Core i5-6200U with Intel HD Graphics 520 (Available with iAMT (vPro), config with 8 GB only)
2.2 GHz, up to 2.7 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores
Graphics
Feature
Graphics
Displays
Feature
Touchscreen
13.3-inch diagonal FHD UWVA WLED BrightView (1920 x 1080) eDP 1.2
13.3-inch diagonal QHD UWVA WLED BrightView (2560 x 1440) eDP1.3+PSR
External
Up to 32-bit per pixel color depth
HDMI
v1.4b Supporting up to 1920 x 1200 at 60Hz
Storage and drives
Feature
Solid State Drives
128 GB SSD 2280 DS TLC / SATA
180 GB SSD 2280 DS MLC / SATA
256 GB SSD 2280 DS TLC / SATA
512 GB SSD 2280 DS TLC/ SATA
Self Encrypting Drive
256 GB SSD 2280 DS MLC / SATA-3 Self Encrypting Drive
Memory
Feature
Standard
LPDDR3-1600 (Transfer rates up to 1600 MT/s)
Dual Channel Support
Memory soldered down
Supports
4096 MB (128 M x 2 x 32 x 4PCs ) - 1600 MT/s
8192 MB (256 M x 4 x 16 x 4PCs ) - 1600 MT/s
Maximum
8 GB
Networking/communications
Feature
Wireless LAN (WLAN)
Intel 802.11a/b/g/n/ac (2 x 2) and Bluetooth 4.0 Combo (Supports vPro)
Communications
Miracast support
Intel WiDI Pro Support
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
HP Noise Reduction Software
Digital Microphones (Dual Array)
Dual Speakers
HP TrueVision Full HD camera
Fixed (no tilt) + activity LED
1 Piece
USB 3.0
M-JPEG
Wide FOV(88 degree)
1920 x 1080 by 30 frames per second
Dual array Digital Microphones
With appropriate software - beam forming, echo cancellation, noise suppression
Software and security
Specification
HP value add software
HP Touchpoint Manager
HP Wireless Hotspot
HP Support Assistant
HP ePrint
Multimedia
Cyberlink PowerDVD / Power Media Player 12
Collaboration
Skype RTC Insertion
mysms-Metro (Windows 8.1 only)
Third party
Buy Office
Adobe Shockwave Player
Foxit PhantomPDF Express for HP
Photos and videos
Intel Wireless display (WiDi)
Intel WiDi Pro
Cyberlink Youcam (Windows 7 only)
HP PageLift
Security
Absolute Data Protect
MS BitLocker
Power
Specification
Power supply
HP 45 W Smart AC adapter
HP 45 W Smart AC 2-prong adapter (Japan only)
AC and DC power cords
1.8 m (5.9 ft)
Battery
HP Long Life 3-cell
56 WHr Li-ion
Weight and dimensions
Specification
QHD Display + 3 cell battery + single mSATA : starting at 1.44 kg (3.17 lb)
FHD Display + 3 cell battery + single mSATA: Starting at 1.48 kg (3.26 lb)
Dimensions (W x D x H)
325 x 218 x 15.4 mm (12.79 x 8.58 x .61 in) (Front)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
Ports / slots
Specification
Ports and slots
(3) USB 3.0 Ports (2 at left; 1 at right)
(1) Mini DisplayPort 1.2
(1) HDMI (Cable not included)
(1) Headphone output & microphone input combo jack
(1) AC power adapter plug
HP multi-format digital media card reader
Support SD/SDHC/SDXC
Push-Push Insertion/Removal
Internal card expansion
One NGFF slot (2230) for WLAN
One NGFF slot (2280) for Solid State Drive
Country: Flag Vietnam
