Remove and Replace the Side Key Button Cable on the HP ENVY 8 Note 5xxx Tablet
This document applies to HP ENVY 8 Note 5000 tablets.
Before you begin
  • Have available a flat-bladed prying tool, battery cover adhesive, and a heat gun.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing and replacing soldered parts or wires, servicing internal components, and or applying heat to parts of the tablet increase the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the tablet.
Video overview
The video and graphics in this article depict a specific configuration of the tablet. These same removal and replacement procedures apply to all configurations of HP ENVY 8 Note 5xxx Tablets.
Removing the side key button cable
Use the steps in this section to remove the side key button cable.
Step 1
First, remove the battery cover.
Take care not to damage the hooks during the removal process.
The battery cover to remove
Step 2
Then remove the rear plate.
The rear plate to remove
Step 3
Remove the middle frame.
The middle frame to remove
Step 4
Carefully disconnect the battery cable from its connector on the system board.
Disconnecting the battery cable
Step 5
Remove the grounding tape that secures the side key button cable to the system board.
Removing the grounding tape
Step 6
Disconnect the side key button cable from its connector on the system board.
Disconnecting the cable from its connector
Step 7
Carefully remove the side key button cable from the adhesive that secures it to the display panel assembly.
Step 8
Place the side key button cable in a static dissipative bag.
Putting the side key button cable in static dissipative bag
Replacing the side key button cable
Use the steps in this section to replace the side key button cable.
Step 1
Place the side key button cable into position on the display panel assembly and gently apply pressure to adhere it into place.
Replacing and pressing the side key button cable into position
Step 2
Connect the side key button cable onto its connector on the system board.
Connecting the side key button connector to the connector on the system board
Step 3
Replace the grounding tape that secures the side key button cable to the system board.
Replacing the grounding tape
Step 4
Carefully connect the battery cable into its connector on the system board.
Connecting the battery cable
Step 5
Replace the middle frame.
Replacing the middle frame
Step 6
Replace the rear plate.
The rear plate to replace
Step 7
Replace the battery cover.
Replacing the battery cover
Country: Flag Vietnam
