HP Spectre x360 - 15-ap011dx (ENERGY STAR) Product Specifications
T6T11UA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB LPDDR3-1600 SDRAM (onboard)
Video Graphics
Hard Drive
256 GB mSATA SSD
15.6" diagonal FHD IPS Radiance Infinity WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit
Pointing device
Wireless Connectivity
802.11ac (2x2) and Bluetooth® 4.0 combo
External Ports
1 HDMI; 1 headphone/microphone combo; 4 USB 3.0 (1 Type-C); 1 Mini DisplayPort
37.8 x 24.7 x 1.6 cm
1.84 kg
45 W AC power adapter
3-cell, 64.5 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen; Quad speakers
Pre-installed software
CyberLink YouCam; Netflix
HP ePrint; HP Support Assistant; HP Connected Photo
Buy Office
