HP Notebook - 15-ac035tx Product Specifications
M9V15PA
Intel® Core™ i5-5200U with Intel HD Graphics 5500 (2.2 GHz, 3 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video Graphics
AMD Radeon R5 M330 Graphics (2 GB DDR3 dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.43 x 25.46 x 2.43 cm
Starting at 2.19 kg
65 W EM AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
Windows 8.1 64
HP Support Assistant; HP Recovery Manager; HP Connected Photo; HP Connected Drive; HP SimplePass
Pre-installed software
CyberLink PowerDVD; CyberLink YouCam; CyberLink Media Suite; Cyberlink Power2Go; CyberLink PhotoDirector; Adobe® Shockwave® Player; User Guide documentation; iPass; Skype; Evernote; Dropbox
Buy Office
